Power steering retro fit question
tomson
Post Wed Aug 23, 2006 6:42 pm
Right i have a full set up from a 1990 320i and im wondering will fit straight into a 1984 323i with manual steering?
Martinaston
Post Wed Aug 23, 2006 6:50 pm
As long as you have the pump mounting bracket i can't think why not.
There is NO nucleus.
tomson
Post Wed Aug 23, 2006 7:06 pm
Thanks, i have the lot ie rack, pump/bracket, pipes, reservior.
stuartgallafant
Post Wed Aug 23, 2006 8:35 pm
shouldn't have a problem. however, im not sure if E30's have an engine compensator thingy (i cant actually remember the technical term for it!!) that stops your engine dying if you turn the steering when at low revs?
dazleeds
old skool raver
old skool raver
Post Wed Aug 23, 2006 8:38 pm
tomson wrote:Thanks, i have the lot ie rack, pump/bracket, pipes, reservior.
belt and pulley also needed
as well as the linkage from steering column to pas rack
doing my sport this week too winkeye
www.oldskoolfantasy.co.uk
tomson
Post Wed Aug 23, 2006 10:16 pm
cool, i have these too but not the "compensator thingy"??? :D
stuartgallafant
Post Thu Aug 24, 2006 8:38 am
like i said, it might not have one. it will be built into the engine somehow, but it basically controls the revs of the engine at idle if put the engine under load at idle.
just ignore me!!!
