hi all this is the quote i got for the above....
paint materials and sundries £124
cavity wax £6.95
welding materials £17.85
1 x offside wheelhousing £26.75
1x nearside wheelhousing £26.75
1x offside rear quater arch panel £29.80
1x nearside rear quater arch panel £29.80
paint materials+parts £262.70
labour £594.75
subtotal £857.45
vat £150.05
total £1,007.50
is this geezer haveing a Fucking laugh or what?
quote for inner + outer arches on the 320.
e30bmlover
- Ac Schnitzer prophet
if it's a really shit hot quality repair shop then probably not mate
I went through a similar situation with my car, which pretty much ended up with a full respray and I think that was about £2700.
needless to say the work didn't get done.
If your plans are to keep the car for a long time then yeah get a good quality job done and you will prob be the + side of £500 at least, but if you are likely to end up going for another car within the next 12 months then I would be more inclined to be a bit more cheap & cheerful
e30bmlover
iv got one more place to try, my mate had his mr2 done there and says the geezer(who turns out to be a relation of his!) is shit hot + hes old school.
Chris-W
e30bmlover
it hasnt got an hourly labour rate chris, hes just give it to me in one go.
here is the description of work.........
remove rear bumper,rear lamps and all trim and fixtures to rear quater panels
cut away corroded outer quater panel arches and inner rear quater wheelhousing panels.
trim and locate panels for welding.
weld inner and outer panels and seam sealer all joints.
galvtop stopper and featheredge outer panels.
prepare, mask off, etch primer and repaint quaters in matching basecote and lacquer and lowbake.
refit all trim and fixtures.
rustproof all work.
wax polish and finish off.
rustproof all work.
e30bmlover
the body shop was ''max bidwell & sons'' rackheath industrial estate.
Chris-W
e30bmlover
i think he thinks im some sort of mug.
e30bmlover
nice one gav i will give them a bell, the 320 will be a gooden then!!!!!!!
bigkev
StuBeeDoo
e30bmlover
yeah thanks. i will give them a bell when i get up on friday(about mid day)
