M52 Crank
StuBeeDoo
Post Wed Aug 23, 2006 6:15 pm
What's involved in fitting an M52B28 crank into a M20 block please??
TIA
Stuart.
tomson
Post Wed Aug 23, 2006 6:34 pm
From what ive read its the same as fitting an m20 crank, probably wrong tho!
Tom
Post Wed Aug 23, 2006 6:36 pm
the bore spacing is the same but some maching work is needed on both ends to make it work. this all i know
Martinaston
Post Wed Aug 23, 2006 6:38 pm
I think they have a timing chain so the sprocket has to be removed or machined off the front :?
There is NO nucleus.
LowLevel
Post Wed Aug 23, 2006 6:39 pm
Realize that the rods are the same length as M52 rods --- which means the wrist pin height is different on the pistons. You're talking about adding a lot of stroke, so you'll need custom pistons, if you can't fit M52 pistons.
-AJ
maxfield
Post Wed Aug 23, 2006 6:40 pm
I guess this is the crank player6 used?
Dan318-is
Post Wed Aug 23, 2006 6:41 pm
Martinaston wrote:I think they have a timing chain so the sprocket has to be removed or machined off the front :?
This is also what iv heard; every petrol BMW engine except the m20/m40 is chain driven as far as im aware.
m52 pistons should fit in the m20 block also from what i remember reading but dont count that one for sure
Post Wed Aug 23, 2006 7:51 pm
just use an eta, 324 diesel less work and very similar performace!
e21Jason
Post Wed Aug 23, 2006 10:51 pm
Hi
M52 28 crank fits but need you a spacer at the fron for the crank seal, use the 320 rods and 325 pistons you get 2.8 with no decking to the block spacer shown below
Jason
StuBeeDoo
Post Thu Aug 24, 2006 5:58 am
Thank you Jason. That's the answer I was looking for. :cheers:
k130
Post Thu Aug 24, 2006 5:42 pm
is that a 2.0, 2.3 or 2.5 block (forgive my ignorance please!)
Martinaston
Post Thu Aug 24, 2006 6:00 pm
So is the spacer bonded on ? (or welded 8O ) to stop the oil escaping.
And what k130 asked :)
StuBeeDoo
Post Thu Aug 24, 2006 6:44 pm
k130 wrote:is that a 2.0, 2.3 or 2.5 block (forgive my ignorance please!)
It would have to be a 2.5 or ETA block.
StuBeeDoo
Post Thu Aug 24, 2006 6:46 pm
Martinaston wrote:So is the spacer bonded on ? (or welded 8O ) to stop the oil escaping.
Interference fit.
ste
Post Fri Aug 25, 2006 2:09 pm
I'd advise leaving the 2.8 crank in the M52 engine and fitting the lot. :D
StuBeeDoo
Post Fri Aug 25, 2006 4:55 pm
Thanks Andy.
Ste.... I wouldn't argue with you on that one, but it means changing the gearbox and diff too.
StuBeeDoo
Post Fri Aug 25, 2006 8:42 pm
Argos wrote:Or just buy a 328i saloon for a under couple of bags
Touring in my case. Need the boot space! :lol:
But anyway, E36 wrongness is not an option!
Ant
Retired Team Member
Retired Team Member
Post Fri Aug 25, 2006 9:18 pm
:lol: cant argue with that .
reggid
Post Sat Aug 26, 2006 10:08 am
Argos wrote:When you're building a 2.7 with the 81mm stroke crank there is a 3 mm gap which means you have to shave 3mm from the block face. The 3mm longer stroke on the 2.8 negates this.
if the stroke is 3mm longer the pistons will only move 1.5mm higher at TDC :?
M5pilot
Post Sat Aug 26, 2006 2:11 pm
E36's are so wrong even if they don't rot as much. Not wrong in a way they are bad cars to drive but the image!
E30's are high maintenance little bastard things but a nice clean rot free one is a joy to own if it runs nicely.
I have to agree with Ste though, just fit the whole engine. You get a free MAF conversion too and an extra 12 valves and camshaft. It's not tappety and fuel economy is much better too.
Sal
M5pilot
Post Sat Aug 26, 2006 4:24 pm
Having thought about it again - I have to agree, some E36's are a very nice place to be.
328i Sport, totally standard in that bright blue colour similar to Avus Blue is simply lush.
E36 M3 in Techno Violet - again totally standard is a machine and half.
But the 4 doors looks so wrong unless they are the M3's.
Alpina B8 4.6 is just porn. Almost the same engine in an E39 (B10 V8) is nearly as quick as an E39 M5 so I can imagine what a B8 would be like! If I could get hold of an nice Blue Coupe I'd take out a loan.
Still a BMW at the end of the day and they do come with more toys.
Sal
SamG
Post Sat Aug 26, 2006 8:20 pm
always prefered 4 door e36 myself, if they are done right can look really good, bloke down road from mes got the 4 door alpina in dark blue and looks nice, not chav atall
