painting rocker cover and inlet manifold
eun
Post Wed Aug 23, 2006 12:26 am
im gonna remove these over the next couple of weeks to paint them.
i want to spray them black and then sand the bmw bits off to reveal the silver underneath.
i would like any info as i know a few on here have done it already
on what paint to use and if poss a sort of step by step guide on the best way to do it.
ive heard about something called hammerite. what is this?
can any paint be used and do you just use normal sand paper on a block to sand off the raised bmw bits?
any help and advice appreciated
cheers eun :D
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Aug 23, 2006 12:29 am
I used VHT paint from Motorworld gave it about 6 coats then block sanded the raised BMW section etc here's a shot of my engine bay
eun
Post Wed Aug 23, 2006 12:42 am
thats the sort of look i want neil.
is that matt black cos i'd probably prefer it to be a bit shinier if poss :wink:
Templ8e30
Post Wed Aug 23, 2006 10:47 am
VHT isn't needed on the rocker and inlet as they don't get hot enough.
Gloss paints burn easily so avoid those, I used Satin black spray and it works brilliantly.
Make sure the metalwork is degreased and as clean as poss then prime it with a weld primer (it etches into the ally so it doesn't flake off) then several coats of satin black.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
eun
Post Wed Aug 23, 2006 1:05 pm
thanks iain
i think ive seen your engine bay before and it looks lovely
il give it a go over next couple of weeks.
just gotta work out how to take both of them off now as ive never done it :mad:
