Right, Gaydon has inspired me to do a bit of work to the old girl.
Anyone know whose front wings are best? Euro or GSF? I ask because I remember someone on here mentioned needing to make adjustments to the ones they bought.
The genuine wings are an extra £100 per side!
Euro Car Parts or GSF???
Templ8e30
GSF wings are much better than ECP's apparently
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Dan318-is
ECP supply GSF with most there parts!
toby
front wings vary a bit in shape through the 3 face lifts so it's important the y give you the right one - otherwise yes you do have to cut bits off the inside back of the wing to make it fit - annoying!
Gibbo
So has anyone had experience fitting a wing to the last facelift model? Any problems?
The GSF wings are marginally cheaper so I'm pleased to read the recommendation from Iain T.
Templ8e30
I doubt that !318-is wrote:ECP supply GSF with most there parts!
For example GSF sell mostly Febi replacement mechanicals and Elring gaskets whereas ECP sell mostly Lemforder replacement mechanicals and Victor Reinz gaskets
I've also found GSF's bushes and top mounts to be far superior to ECP.
I usually shop at GSF unless it's something electrical as they don't stock much electrical gear, that's when I go to ECP
Cheers,
Iain T
H-M3
Try linwarmotor.co.uk.
Bob_S
personally I would find 2 good wings at a scrap yard or buy from BMW, ECP are shockingly bad in chester so i cant see them being much better elsewhere
Bollocks to this 24v scrap!
