I know nothing, any ideas? good or bad? if good what would be needed?
http://atsearch.autotrader.co.uk/WWW/CA ... 2101382164
is this a good engine for a conversion?
320Touring
words like "high miles and oil leak" set the alarm bells ringing
i'd have been in there before you (saw it at 6am on fri morning) otherwise, make a proper kouncil king khariot
320Touring
dude, to me, Kiev is a long way, london is a daytrip!
yeah its v8-4valves per cyl and this is an early one-4.0 instead of the 4.4 one
nikasil issues abound
as for the gearbox, pass
Dan318-is
im 99% sure that will be an auto tony. m60 lumps had nikassil issues didnt they? an everett article once informed me that you must NEVER stop adn start them for short journeys; once they are turned on they must be left to warm up completely then switched off, this is what iv read. your on the rite track i think.
re you going to swap running gear too?
^Dan just spotted it last night,started thinking all sorts of E30porn about sticking it in this -
http://www.e30zone.co.uk/modules.php?na ... 275#432275
but ive just been reading about nikasil and dont fancy all that crap,might just stick to a 2.5!
320Touring
only problem with your plan 318-is is that e34 suspension wont fit on the e30
needs to be a mix of e36/compact stuff or e30m3 gear.
eko-just fit an m30!
bazman
Tony - PM me if you are interested in the E34.
Baz
Baz
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
