MS guys - Fast idle valve?
tim_s
been playing with my pwm idle valve today and its not really working right. What's the best source for a simple on/off fast idle valve? mine idles at about 500rpm when cold (and annoyingly dies when you touch the throttle), 800rpm when warm. don't really want a veedub aux air valve, would prefer something cheap and simple i could plug into MS and set to turn off at a specific coolant temp.
tim
tim
Ant
- Retired Team Member
Golf Aux air valve is the cheapest and easiest option Tim, you can use MS to turn the heater element on and then work out the lead in time required to give the desired chacteristics.
make sense-ish dude ?
Email FTW
tim_s
yeah, ish! so you'd use the MS to shut the valve when warm? hadn't thought of that cos on the veedub it came on with ignition, and slowly shut itself over a few mins as it heated up. that the right one im thinking of? had one on my mk1 gti?Ant wrote:Golf Aux air valve is the cheapest and easiest option Tim, you can use MS to turn the heater element on and then work out the lead in time required to give the desired chacteristics.
prob is it worked on the golf cos it was right near the exh manifold and attached to engine so got hot quick and shut itself even without the 12v when the engine was warm. i've got nowhere on the bm block to mount one, so i'm worried that if i do a warm start, the valve will be open and take a few minutes to close off of MS? have i got that right?
is it the only cheap/easy option you reckon ant?
Ant
cheapest soloution is a wax-stat, but we all know how reliable they can be
Mk1 gti style valve is spot on, and can be remote mounted anywhere
Email FTW
blingsta
- Boost Junkie
Ant, does this mean that with m/s, on cold mornings, car wont run very well from cold?
tim_s
depends what you do for idle! MS is theoretically capable of controlling more or less any idle device, so as long as you put enough time and effort into it it will be at least on par with the factory system. lots of people running MS just ignore the poor cold running without an idle device and don't bother with one - I use my car as a runaround so I need a good cold idle. I'm sure if you get an Ant MS solution, the idle will be spot on.blingsta wrote:Ant, does this mean that with m/s, on cold mornings, car wont run very well from cold?
I don't have lots of time and energy to devote to this problem on mine, so just want a quick and simple solution. The golf valve is pretty good in that respect, but I'm a bit reluctant as I wanted a device that MS could have complete control over, which isnt really the case with the golf valve as they shut slowly (a few minutes) when you give them 12v.
tim_s
bollocks. just bought one of these from my favourite veedub breaker (volksmania) and it doesnt work properly. only half-shuts when on 12v for a while, still lets some air in. gets hot though. all too familiar, have never liked these things! will have to do the 40 mile round trip again to pick up another one, wish i'd tested it while there
Ant, do you know if there's any adjustment on these air valves, there's a small nut on the back i thought i might play with before returning it?
on an unrelated note, do you have any idea why my car still runs (very nicely i must add, if a bit tamely) with motronic controlling the sparks? I have no AFM so was expecting it not to work on motronic as it has no load signal, but in fact, the sparks are better on motronic than my in-progress MS one. is there any easy way to get the same sparks map into MS? I looked in the bentley, but there's nothing there. my advance timing light is not accurate enough for this either, i might ask sheps next time i'm on his rollers though but i'm not sure how accurate we'll get there either.
jamesc
Apologies for the maybe dumb question, but do you still need this with a turbo or should it feed straight into the TB?
James
James
Ant
"need"
well debatable, can you live with starting the car, then holding the rpm @ 1.2K for 20 seconds, after that mine idles perfect on the warm up settings.
TBH, wityh FI you want as many leak sources removed from the system as poss James.
Email FTW
jamesc
Thats what I was thinking, I think I will go without. My cars not a daily driver so its not too much of a problem.Ant wrote:"need"
Cheers, James
e30_Turbo
- Boost Junkie
jamesc
Cool. Slowly building mine too when I get some time spare here and there
e30_Turbo
- Boost Junkie
