Anyone is sitting on details of this engine (who done it, what problems he solved, etc.)?
Cheers,
Jan
For 99% it is. It is nothing unusual to change the sides in cylinder head (IN in place of EX and vice versa).Turbo-Brown wrote:Surely that can't be a V12 block with two M50 heads. If it was, the exhaust of the left hand head would be firing at the inlet of the right hand one, unless they swapped the end the cams are driven from on one of the heads that is.
Exactly. When you are porting the head and fitting bigger valves there no any disadvantages to do this.Turbo-Brown wrote:What, drawing air in through what used to be the exhaust ports on one of the heads?!
I don't think you would ever get both banks to run the same though.Yaninnya wrote:Exactly. When you are porting the head and fitting bigger valves there no any disadvantages to do this.Turbo-Brown wrote:What, drawing air in through what used to be the exhaust ports on one of the heads?!
What you mean? 850 CSi was 2 v per cyl.Ant wrote:cant see the poit in this head conversion though, for the cost and effort possibly easier to source a late Csi lump and use that to get the 4v per cyl
trueYaninnya wrote:What you mean? 850 CSi was 2 v per cyl.Ant wrote:cant see the poit in this head conversion though, for the cost and effort possibly easier to source a late Csi lump and use that to get the 4v per cyl
Yes, but second hand N73 is expencive as hell.Kos wrote:they did develop a 48 valve version of the v12 but never put it in to production, ... ...but a few years later they did
wrongWillG wrote:850 csi doesnt use a m70, its uses a S70 and has 4 valves per cylinder according to http://dave.maisenhelder.com/bmw/engines_&_chassie.htm and http://www.realoem.com/bmw/
same castings as maclaren FI engine
Let's get some light on V12 mistery:WillG wrote:already did that, so its that a maclaren F1 engine isnt a S70, that still doiesnt explain why he has all the s70 engines as having 4 valves
dont think i would trust any of the v12 info on there, everything on m20's seems to be correct tho
