Should I Spray the Alpina Mainifold??
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Aug 18, 2006 12:47 am
Guys
Just got a Alpina Mainifold off Blingsta (cheers fella)
Should i spray the pipes black or silver or should i just leave them as is???
Here is a pic (thanks again Bling for the Pic)
this is my engine bay at the moment,
what would u do??? spray it or not silver or black ??
thanks
Neil
maxfield
Post Fri Aug 18, 2006 12:54 am
Leave it as it is :cool:
Kos
Post Fri Aug 18, 2006 2:21 am
get them sand blasted first, then use VHT black paint, then silver. they do have a habit of corroding a bit and can look scatty so a take it back to metal and put on a fair coats
by th way i know a man who sand blasts !!
delphini
Post Fri Aug 18, 2006 2:42 am
YEAH what he said ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
SilverShadow
Hartge Crew
Post Fri Aug 18, 2006 10:17 am
Get it polished!!!!
Gouki
Post Fri Aug 18, 2006 10:27 am
as your inlet manifold is of a silver colour, be nice to match it up with the 6 brancher u have in there. Plus it stands out more compared to black.
WillG
Post Fri Aug 18, 2006 11:27 am
would spray it black, dont like silver paint on exhausts
nwmlarge
Post Fri Aug 18, 2006 11:39 am
what about getting it ceramic coated
its about £150 ish to get done
Ant
Retired Team Member
Retired Team Member
Post Fri Aug 18, 2006 12:21 pm
wrap in thermal barrier tape, then paint it silver to seal the tape
almost as pukka going ceramic, at a fraction of the cost dude.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Aug 18, 2006 1:02 pm
Ok gonna do a heat rap and spray it up cheers ant.
Im gonna stick on as is for the time being and then come october im gonna strip her down at the lock up, Ill do the mainifold, rocker cover again and re polish the inlet again.
Gonna also replace some other engine bits aswell
stuartgallafant
Post Fri Aug 18, 2006 1:07 pm
you just cant get enough can you!!! good man 8)
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Aug 18, 2006 1:09 pm
stuartgallafant wrote:you just cant get enough can you!!! good man 8)
:lol: i have the bug mate
mattG
Post Fri Aug 18, 2006 1:11 pm
clear powdercoat is not bad for polished ally can save a lot of repolishing
appletree
Post Fri Aug 18, 2006 3:30 pm
IMO i like it as it is but. if you was going to heat rap i would leave it in just heat rap. is that stuff any good by the way???
Demlotcrew
Post Fri Aug 18, 2006 3:35 pm
I wraped mines and its one of the best things i did while building the engine.
Andrew
stevetigger
Post Fri Aug 18, 2006 3:36 pm
8O Thought you had a cab, not a beetle? :mad:
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Aug 18, 2006 3:38 pm
winkeye :lol:
