Heater control panel....... help please!!
miniblob
Post Thu Aug 17, 2006 1:33 pm
Right then, any advice on how to get this out/off???
I mean the plastic surround that houses the clock, stereo and heater controls!!
Need to change mine to a lhd one (which i have) and was wondering if anyone has any tips & instructions for this job!!
Had a look in my haynes manual, but it didn't help much!!
Might go and have a poke about later and see what happens!!
327 Touring with bass!!!
miniblob
Post Thu Aug 17, 2006 1:47 pm
Also, do all the heater knobs just pull off?
A1BMW325iSport
Post Thu Aug 17, 2006 1:56 pm
switches at top pull out, 2 small screws on inside edge pointed diagonally up into dash
pull off lever knobs then the slider panel, 4 screws behind that hold facia to the slider/cable part
then the gearlever console to remove.. remove ashtray and then the 2 screws and unplug wiring, 2 clips at rear corners of console by heater box, one plastic 10mm nut at rear of console, then one 8mm bolt above ashtray area (holds centre console to dash through metal bracket)
then once the centre console is out you can get to.. the 2 screws that hold heater panel at bottom of bash
Last edited by A1BMW325iSport on Thu Aug 17, 2006 3:28 pm, edited 1 time in total.
miniblob
Post Thu Aug 17, 2006 2:03 pm
Nice one!! Cheers mate.
Might have a bash at that later!!
