A load of questions from a new e30 fan
SPADGE
Post Wed Aug 16, 2006 9:43 pm
Hi all
Can somebody answer the following if poss please or i'll be posting numerous 1 question threads all night lol :mad:
What ratio is a 93 318i Lux manual diff? And is the cwp the same size as the item in a 325??
Is the gearbox from the above car the same as a 325i item or totally different?
What is the best ratio lsd to use for an M30'd touring 3.6 or 3.9?
Where can i get the engine brackets for mounting the M30 into the touring and how much?
What is the bit i need to change in the dash pod to convert from 4 cyl to 6cyl for the rev counter etc to function correctly and would this item from an E34 fit and work in the E30??
I have seen a few E30's on here with 5 stud hubs. What are these from?? E36? and what is involved in changing them????
That'll do for now any help appreciated and sorry for being a pest lol :D
ed325i
Post Wed Aug 16, 2006 10:03 pm
You can get them from www.e30.de
I made my own.
ed325i
Post Wed Aug 16, 2006 10:04 pm
Look at this link>> http://www.ubersaloons.co.nz/uber3/5lug.htm
Or get the e30 m3 set up.
ed325i
Post Wed Aug 16, 2006 10:06 pm
The gear box is different.
Andy335Touring
Post Wed Aug 16, 2006 10:58 pm
I think ones a small case dif and the other will be a large case so i'm not sure you could swap the internalls around. You want a large case dif because the small case carn't handle the M30 torque.
Assuming you will be using a non-dog leg g/box and standard sized wheels/tyres you want a 3.6 or a 3.46
SPADGE
Post Wed Aug 16, 2006 11:17 pm
Hi cheers for your reply
I was going to use the box from the e34 donor car that the engine is coming out of i assume this is ok?
I'll source a large case lsd then and yes standard sized rims will be used.
SPADGE
Post Wed Aug 16, 2006 11:18 pm
ed325i thanks for your replys!
Andy335Touring
Post Thu Aug 17, 2006 4:58 pm
SPADGE wrote: I was going to use the box from the e34 donor car that the engine is coming out of i assume this is ok?
Yes it's fine, was it a Sport ?
SPADGE
Post Thu Aug 17, 2006 10:49 pm
No mate a 535i se
