Did i say earthBrianmoooore wrote:Other big nut on the solenoid is certainly not an earth. It's the switched 12V+ to the starter motor.Andy335Touring wrote:Two little ones and the main big one, the other big nut is the starter to solenoid earth i think ?
If your solenoids have two small terminals, what is the problem you have with the unloader relays?
I thought i had a problem with the unloader relay a while back but i don't, you can hear the interior fan cut out when the starters going so assume it's working/wired up OK ?
