Poor running, cutting out :(
Morat
Post Mon Aug 14, 2006 12:15 pm
Folks,
My 325 has recently started being a bitch :(
Levels are fine, fan just had a new visco clutch after a close call with overheating. It ran sweet as a nut for a couple of months during the heat and now its doing the following:
1. Starting first time on 4-5 cylinders with lots of smoke. If you leave it for a few seconds it clears up and idles properly.
It did that for a while and now...
2. After about 15 minutes in traffic or running steady it will start choking up. Starts smoking, doesn't like full throttle (judders on full chat) and eventually it will just cut out. If you drop the clutch and rag it up to 5.5k revs 2-3 times it will settle down again for a while. If I'm trashing the car round country roads its quite happy.
I've got a new blue temp sender to stick on this week but I'm wondering if there is anything else you guys could suggest that might be causing all these probs.
Cheers!
Morat
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Aug 14, 2006 12:23 pm
Have u check the rubber boot (goes between the air flow meter and TB) for cracks or air leaks???
Morat
Post Mon Aug 14, 2006 12:24 pm
yes mate, its a new one. Bought it about 2 months ago now.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Aug 14, 2006 12:26 pm
Blue temp sensor might help, IM guessing u have already clean the ICV
Have u replace the air filter of anything???
Post Mon Aug 14, 2006 12:27 pm
is the smoke you are getting oily/blue smoke and smelling of the same or is it more of a sooty black?
If it's sooty black and your tailpipes are accordingly so, then that suggests horrendous overfuelling, most prob rectified when you replace the temp sensor. Well, it's where I would start anyway.
Steviec
Post Mon Aug 14, 2006 12:42 pm
Dumb question time :oops:
Where is the ICV and what does it look like?
(Sorry for being thick, im still learning my way around the engine bay).
<a><IMG></a>
Post Mon Aug 14, 2006 12:45 pm
Steviec wrote:Dumb question time :oops:
ICV = Idle Control Valve
In the pic below, look at the throttle linkage and then just to the right of that, there is a silver part sticking out with a hose coming from it. Well the silver part is the ICV. Sits just on the side of the inlet bellow before the throttle body
Post Mon Aug 14, 2006 12:47 pm
Morat
Post Mon Aug 14, 2006 12:48 pm
Well, its not sooty black...more blue - which doesn't sound good. On the move it can be white - but its not using any coolant. It does use about half a litre of oil every 750 miles or so.
I've just been out and checked out the exhaust, there's definitely some oil burning, I'm praying that its not valve stem seals - or if it is, its not bad enough once I've fixed the rest!
If you rev the engine with your head in the bonnet (with the throttle cable) there's definitely a sucking noise and a hesitation before it picks up off idle so I think there could be some more leaks somewhere.....
I'll check it again with the engine properly warm, thats when it starts playing up.
Thanks for your help guys, if you have anymore ideas....
maxfield
Post Mon Aug 14, 2006 12:49 pm
Blue smoke normally means its burning oil and pistons rings are gone.
Post Mon Aug 14, 2006 12:52 pm
my only other experience of poor idle was down to the inlet gasket going. Symptoms were lumpy uneven idle and also a bit of kangaroo behaviour when crawling along in say 3rd gear on light throttle trying to maintain a constant 30mph.
with it running, spray wd40 around the inlet manifold where it bolts to the head, if normal idle is restored then that would be your problem
But i think with the blue smoke issue, it must be something else. Perhaps worth investigating breather pipes from crank case and the pipe that goes from low down on the block to the underside of the inlet manifold.
Ask JAMZ, he's just had a load of grief replacing this part as it is a fanny on to put back together.
Smoke on startup etc, usually valve stem seals
Smoke when blatting it and on overrun is usually piston rings I think
maxfield
Post Mon Aug 14, 2006 1:03 pm
I thought it was just piston rings when oil was burning but you learn something new everyday
Dan318-is
Post Mon Aug 14, 2006 1:06 pm
maxfield wrote:Blue smoke normally means its burning oil and pistons rings are gone.
Not always young one, stem seals can also be kaput.
Sparkysparks
Post Mon Aug 14, 2006 1:11 pm
Hi, my 318is does this, the rubber boot between the intake and air filter is well cracked though, BMW have had one on hold for me for about 6 months now, im hoping this will cure it, although ive been advised to get another idle control valve, but i dont wanna pay £80 for something smaller than my middle finger, and i cant find a second hand one that fits my car.
Post Mon Aug 14, 2006 6:38 pm
get a used one, I flogged my spare one for £15
put a wanted ad up, plenty of people breaking cars at the moment
Morat
Post Mon Aug 14, 2006 10:03 pm
ack, drove it home from work - took about 30 minutes. 5 minutes cross country to the A-road, 15 minutes on that and 10 minutes through York.
By the time I got home it was hardly running at all. It would die at idle, it wouldn't rev, kept dropping out cylinders and cutting out altogether. Its weird, if you rev it up it seems to clear and run normally for a few minutes and even idle properly. Then it starts playing up again. I'm not going to drive it anymore till the blue temp sensor is replaced and then it'll be a test drive cos right now its dangerous :(
Morat
Post Tue Aug 15, 2006 11:11 am
Well it wasn't the blue temp sensor - it turns out that the MAF sensor had a dry joint and was giving the wrong reading to the ECU. It has been cracked open, repaired and glued shut again. Once its dry I'll be able to have a test drive and see.
Here's hoping! 8O
Post Tue Aug 15, 2006 12:30 pm
do you live in/ near York then fella?
What colour is your chariot?
320Touring
Sparkysparks wrote:Hi, my 318is does this, the rubber boot between the intake and air filter is well cracked though, BMW have had one on hold for me for about 6 months now, im hoping this will cure it, although ive been advised to get another idle control valve, but i dont wanna pay £80 for something smaller than my middle finger, and i cant find a second hand one that fits my car.
dude-the iS one is the same as fitted to the 318i m40 limp-plenty of them in scrappers-"borrow" a few, can of carb cleaner and bobs your mothers brother winkeye
Fingers crossed Morat :D
Morat
Post Tue Aug 15, 2006 12:47 pm
E30BeemerLad wrote:do you live in/ near York then fella?
White, if you can see past the smoke :cry:
I live off scarcroft road, and someone has a very tidy dark blue touring K reg nearby - is that you?
Post Tue Aug 15, 2006 12:49 pm
No not me mate, I live in Haxby
massive
Post Tue Aug 15, 2006 1:23 pm
Morat wrote:Well it wasn't the blue temp sensor - it turns out that the MAF sensor had a dry joint and was giving the wrong reading to the ECU. It has been cracked open, repaired and glued shut again. Once its dry I'll be able to have a test drive and see.
Here's hoping! 8O
How did you find this out?
Morat
Post Tue Aug 15, 2006 1:45 pm
I didn't - but I'll ask the man who did it.
edit:
He has an autodata CD which tells him the readings he should get off the various components and also what the ECU should be saying. He checked it out and the air flow meter was playing up. Didn't solve the problem tho :(
Sparkysparks
Post Wed Aug 16, 2006 11:09 am
Cheers buddy, i takeit your talking about the ICV, ill have to look into that. :)
