Ceramic 'power boost' resistors
Post Sun Aug 13, 2006 9:49 pm
Seen these advertised a few times on e-bay, has anyone tried one on their E30 or are they as completely bogus as I suspect they might be?!
http://cgi.ebay.co.uk/15BHP-MOD-BMW-316 ... dZViewItem
Cheers!
fuzzy
He who sleeps with "Gingers"
Post Sun Aug 13, 2006 9:52 pm
never tried it but id reckon anything that offers 15bhp for a couple of quid would be bollocks :mad: maybe you should buy one and report back with your findings? winkeye
fuzzy
Post Sun Aug 13, 2006 9:55 pm
i also note it states it will not harm your engine in any way then has a disclaimer against any damaged caused by fitting this product at the bottom :mad:
smithy318i
Post Sun Aug 13, 2006 10:11 pm
DO NOT BUY THIS.
you need a slap across the face with a wet fish if you buy it.
Post Sun Aug 13, 2006 10:18 pm
Probably as shite as those 'Carbonflo' tablets that you dropped in your fuel tank to miraculously convert a leaded fuel-only engine to run on unleaded (Practical Classics ran a test on them and the cylinder head was shagged after only a few thousand miles!), or the cheap bolt on economy/power boosters that have been peddled over the years...out of interest, has anyone had any positive results with an Ecotek valve on their E30?
fuzzy
Post Sun Aug 13, 2006 10:23 pm
i imagine it would be similar to the other resistors previously seen on ebay that was added to your air flow meter and allegedly confused the sensor into allowing more fuel to be pumped in giving much worse mpg and no extra power.if they really did work it would be the first mod every garage recommended :roll:
kam-325i
Post Mon Aug 14, 2006 6:26 pm
stevetigger
Post Mon Aug 14, 2006 6:32 pm
Ebay_247 wrote:No soldering is involved - It's safe & easy to fit (average 2 minutes).
How would you fit it then, bluetack?
nickso
Post Mon Aug 14, 2006 6:46 pm
as fuzzy said its to confuse the injection into piling more fuel in....its worthless and i know cos a mate from work bought one for a laugh on his vectra gsi and it did sod all :mad: ....might as well set fire to a fiver :D
'88 e30 328i M52 track bint.
tommy22
Post Mon Aug 14, 2006 6:51 pm
i was a mug and bought one and chucked it in the bin
