Rear suspension trouble, bushes?
speedyg
Post Sun Aug 13, 2006 2:44 am
Hi,
The car is a E30 325i.
The car has had this problem since I bought it.
When going over potholes, bumps, cats eyes etc the rear of the car feels like it kicks sideways (like it has been pushed from the side). Something feels a bit loose. The car wanders a bit too, especially when going over different road surfaces.
Also when the car is cold it is very easy the get the bunny hops when slowing down.
I've had the suspension checked by a suspension shop and it came back as not needing anything doing, even after explaining what is happening.
It used to have motorsport suspension but now has the Bilstein streetline kit. The car has had a wheel alignment. The car did this before and after the suspension change and wheel alignment.
I am thinking along the lines of rear trailing arm bushes, subframe bushes, broken diff mount bushes etc.
Any ideas? Or has anyone else experienced a similar problem?
Thanks in advance....
Martinaston
Post Sun Aug 13, 2006 1:07 pm
You should have a gap of about 4-5mm below the rear bush, you should just be able to get your finger tips between the bush and the plate underneath.
If you can't then the bush has fialed and the carrier has dropped.
There is NO nucleus.
Sharabi
Post Sun Aug 13, 2006 1:27 pm
Have a similar problem on my 318is, but have been told that its the Rear Subframe bushes.
The Mechanic told me that he has never changed the trailing arm bushes on an e30, but has changed loads of Rear Subframe Bushes.
I'm upgrading them to Powerflex items, think they are around £50, then fitting (been quoted £60 per side) ontop.
HTH
jon_pure_british
Post Sun Aug 13, 2006 2:02 pm
my car is in for rear sub frame bushes
and i did experience the sensation where the car feels like it taps out a bit over bumps..etc
Clacton-On-Sea
Essex
cougar
Post Wed Aug 16, 2006 10:16 am
Martinaston wrote:You should have a gap of about 4-5mm below the rear bush, you should just be able to get your finger tips between the bush and the plate underneath.
If you can't then the bush has failed and the carrier has dropped.
are u taking about sub bushes cos i had them changed last year for mot
this year mot man said the bushes have a gap and i should go back to the garage and have them pushed up more (not failed thou)
