My OBC backlight flickers (goes dim) whenever I use my indicators, wipers or brakes. As is goes from bright to dim everytime the wipers move or indicators flash.
Does anyone else have this problem?
Can anyone help me stop this happening?
** OBC flickers with Indicators, Wipers, Brakes HELP!! **
Project_E30
Gotta be a bad earth somewhere.
At a guess, as its common between them, check the battery to chassis is making a good clean contact?
TouringMatt
I get this, mine seems to pulse too. Never annoyed me enough find the fault, plus id probably just end up breaking something else in the process
Be interesting to hear if you find a solution, sorry i cant help more
Martinaston
There's a couple of ground points on the steering columb and one above the glovebox.
There is NO nucleus.
Project_E30
Do you have any pics so I can find their location?Martinaston wrote:There's a couple of ground points on the steering columb and one above the glovebox.
I know thats lazy but knowing my luck & I wont find them.
Project_E30
Project_E30 wrote:Do you have any pics so I can find their location?Martinaston wrote:There's a couple of ground points on the steering columb and one above the glovebox.
I know thats lazy but knowing my luck I wont find them.
Martinaston
Take the steering wheel off and remove the cowling and you should see two at the top of the columb.
I think there may be another one up by the ECU, not sure.
Project_E30
Are these points clear on the RealOEM website as at least then I can see what I'm looking for
