Engine rattle - 325i
TouringMatt
Post Tue Aug 08, 2006 5:26 pm
Always had a high rev plasticy sounding rattle that you can hear on WOT, tappet or injectors are noisy and clutch release bearing aint the quietest either - but i have a new rattle :(
Noticed it when pulling out of a juntion that was between two high sided buildings (great for echo diagnostics :wink: ) then also heard it in 2nd gear. Was very low on fuel at the time but after i filled up i could just about hear it under heavy load too.
The best way to describle it a low metallic noise
Car drives fine, shows no signs of problems etc, just wandered if its a warning of something about to go wrong
Always difficult to diagnose stuff over the net i know... :(
Matt
TouringMatt
Post Tue Aug 08, 2006 9:23 pm
:roll:
stevetigger
Post Tue Aug 08, 2006 9:50 pm
Could be a bunged oil pick up, when driving hard it can't pick up enough oil!
No doubt a pro will come along and tell ya different :?
gcorky
Boost Junkie
Post Tue Aug 08, 2006 9:55 pm
stevetigger wrote:Could be a bunged oil pick up, when driving hard it can't pick up enough oil!
lol-steve have confidence?
which area does it sound like engine-box-prop-diff-exhaust?
is it in time with engine revs?
525 sport
Demlotcrew
Post Tue Aug 08, 2006 9:56 pm
If it was an oil pick up problem it would manifest it self with the idiot light coming on.
Sorry but you will need to describe it better than "low metallic noise"
Andrew
stevetigger
Post Tue Aug 08, 2006 9:58 pm
Demlotcrew wrote:If it was an oil pick up problem it would manifest it self with the idiot light coming on.
Andrew
I see the sense in that, Reason I say is.......
My 323i would make strange noises under load but only top end of the rev scale.
Was the oil pick up bunged :?
Not saying I am right, just another thing it could be!
TouringMatt
Post Tue Aug 08, 2006 10:15 pm
Thanks for the replys guys
Always difficult :mad:
Its a big like a quiet version of a diesel clatter if that makes sense...........
Oil pressure light hasnt come on when driving at all, but have noticed it doesnt go off as soon as the engine is started, all the abs etc lights go out then oil light flickers and goes off
Noise sounds like its coming from the top of the engine, tis weird, cant really say that it rises/gets louder with revs, it just seems to be there :td:
Dont stress guys, hopefully the car was having an off day :)
Matt
stevetigger
Post Tue Aug 08, 2006 10:16 pm
Just getting long in the tooth then.
Matt, Did you see I put the springs from your touring to good use?
gcorky
Boost Junkie
Post Tue Aug 08, 2006 10:42 pm
it isnt an exhaust leak at manifold /head is it?
all your studs still there...this can give a ticky type noise.?
525 sport
TouringMatt
Post Wed Aug 09, 2006 2:44 pm
Half the studs are long gone mate and there is a huge crack in the exhaust manifold, im used to these noises :roll:
This definatly sounds more mechanical, im not gonna stress about it, i'll just have to get my spare engine ready in case :(
Yeah ive seen the pics Steve, looks good fella 8)
stevetigger
Post Wed Aug 09, 2006 8:29 pm
Thanks mate!
