i think i have all the bits for the electric sunroof conversion, could anyone list me all the bits required?
is it basically bolt one, strap up the wiring loom and attach to befind the glove box and sorted?
smithy318i
motor
mounting plate
relay
wires
switch
mounting plate
relay
wires
switch
You'll save a lot of problems if you get the motor with the full mounting plate and all the guide tubes still attached.
Wind the old guide tubes off the flexible operating wires, and feed them into the new ones.
tomson
Front head lining panel is different also on saloons, on a touring its the whole headlining!
But a saloon panel will fit.tomson wrote:on a touring its the whole headlining!
tomson
how do you mean Brian?Brianmoooore wrote:But a saloon panel will fit.tomson wrote:on a touring its the whole headlining!
A1BMW325iSport
as brian said replace the complete mounting plate with guides, i did that on mine, and cleaned and regreased the cables on re-fitment
dark_sounds
hmm will check to see if i have the mounting plate.
eamo
what are the guide tubes??
A1BMW325iSport
cliffybabe
- Powered by Nelly
Ali if u need one mate me and the boys r going to pea's on Sat morning if theres anything u needdark_sounds wrote:hmm will check to see if i have the mounting plate.
You can cut away the front of the touring headlining with the hole for the manual winder and then cover up the damage with the front panel from a saloon and a bit of the foam plastic around the front of the sunroof apeture.tomson wrote:how do you mean Brian?Brianmoooore wrote:But a saloon panel will fit.tomson wrote:on a touring its the whole headlining!
dark_sounds
oo ek! ill have a list for you then sonny!cliffybabe wrote:Ali if u need one mate me and the boys r going to pea's on Sat morning if theres anything u needdark_sounds wrote:hmm will check to see if i have the mounting plate.
