Turbocharging a 320i.. feed me some info lol
dan_emaps
Post Mon Aug 07, 2006 1:04 pm
Guys,
I'm currently storing my 320i Touring with the plan now being to slowly tune it over the coming months (the joys of a garage :D )
I would like to turbocharge it as i've been inspired by a few projects on here, namely the m30 turbo and the m40 :cool:
I would like to stick with my 320 engine as i really dont want to get into hauling entire engines out of cars and all that worrying if the new engine is good etc etc (been there done that!) also i'm thinking about budget, and although i imagine a 325 lump would be a far better base my 2.0 seems a good solid unit and would seem a shame to do nothing with it.
So onto the next question... is there any glaringly bad reasons why i shouldnt stick with the 320? how is it for compression?
Heres a basic idea of the parts i'm hopig to use and the figures i'd like to achieve, does this sound sensible and also realistic?
T3 Turbo (volvo?), Megasquirt management, uprated cam, a form of front mount intercooler, hopefully a manifold from a zoner (wonder if i could commission someone to help me here lol) uprated injectors, i'm guessing these would be required, or maybe secondaries?
I would like to see over 200bhp without putting the engine under serious strain, does this sound feasable?
Thanks chaps!
gcorky
Boost Junkie
Post Mon Aug 07, 2006 1:18 pm
well you would need sump off anyway,and considering your 40 bhp down to start with id swap a 2.5 in first.
no cam required with 2.5 as duration is allready suitable for f.i,first job -track down a suitable manifold to mount turbo and the rest is readily available.
200bhp is acheivable on an m20b25 without turbo.with 300 bhp is do-able. :mad:
525 sport
Geeman
Post Mon Aug 07, 2006 1:20 pm
if you're swapping blocks, might as well go 2.7 while you're at it. winkeye
e30_Turbo
Boost Junkie
Post Mon Aug 07, 2006 3:45 pm
200bhp from a FI M20, easy as.....
Would have thought Malcs M40 turbo was getting on for 200 or so and that's a 1.8!
IIRC 7 psi on a M20B25 with a t3 is about 220bhp @ the wheels.
But if you're only after 200bhp or so I'd go S/C, much easier to install and get working right.
HTH, Mark.
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 07, 2006 5:59 pm
Disagree Fozz, supercharger is more £Â£Ã‚£ to outlay, and less outright bhp unless you can get the drive pulley ratios spot on. also a lot more grief to fit and plumb as I'm sure Lennie can confirm 8)
2.0 M20, std cossie T3 turbo, manifold etc to suit, be a cool weapon methinks
certainly go a lot better than stock :lol:
dan_emaps
Post Mon Aug 07, 2006 7:44 pm
gcorky wrote:well you would need sump off anyway,and considering your 40 bhp down to start with id swap a 2.5 in first.
Why would i need the sump off dude?
I really have decided against a 2.5 guys, i'd like to do this conversion for a fair bit less than it would cost me to fit say a 3.0 M3 engine, if i start messing about with buying new lumps etc then i can see the budget going out of the window and probably ending up costing me as much as M Power would.. besides, 320 turbos don't seem too common :cool:
So can i assume the compression will be fine? and also could i use a 325 cam? if i can get 220-230brake that would be awesome, but anything over 200bhp would be cool!
Anyone fancy helping me with a shopping list? so i can get a better idea how much this will all cost..
So i need:
T3 Turbo
actuator
Intercooler?
Injectors?
Manifold
new engine management
What else?
Ant - if i had everything done bar ecu and wiring, could i bring it to you to wire the megasquirt in and map it?
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 07, 2006 9:05 pm
No worries Dan :cool:
Post Mon Aug 07, 2006 9:11 pm
Why not bother with the 2.5.. it'll only cost £200or so more for a lump and have a 40bhp headstart with much more torque
fuzzy
He who sleeps with "Gingers"
Post Mon Aug 07, 2006 9:20 pm
wouldnt it be a false economy sticking by your 2 litre? much of your turbos power will be used up just getting you to the 2.5's starting point.id think a decent 2.5 could be picked up from a trusted zoner for a couple of hundred quid giving you a better starting point.even done as cheap as possible its surely going to cost a grand or two anyway.i wouldnt recommend buying the cheapest parts you can find when it comes to turbos etc either as they are notoriously dodgy parts to buy second hand at the best of times,as i and a couple of other zoners have found out to our cost :roll: what sort of budget do you have?
gcorky
Boost Junkie
Post Mon Aug 07, 2006 9:34 pm
So i need:
T3 Turbo
actuator
Intercooler?
Injectors?
Manifold
What else?
oil return from turbo to sump. :)
525 sport
WillG
Post Mon Aug 07, 2006 9:41 pm
some better head bolts/studs and a MLS gasket and a dumpvalve
Post Mon Aug 07, 2006 9:46 pm
if the stock 320 lump is being retained, would it not be an idea to use the 325 inlet manifold and poke the inlet ports out to match, to get as much air in as poss? cheap mod even just to go with the manifold as i guess head off to do the machining for the ports :(
greg320i
Post Mon Aug 07, 2006 10:34 pm
E30BeemerLad wrote:if the stock 320 lump is being retained, would it not be an idea to use the 325 inlet manifold and poke the inlet ports out to match, to get as much air in as poss? cheap mod even just to go with the manifold as i guess head off to do the machining for the ports :(
then whilst your at it use the 325 throttle body,by then you may aswell just drop the 325 and have that extra for all the peeing around all IMO :D
dan_emaps
Post Mon Aug 07, 2006 10:45 pm
thanks for all the info so far guys.
The thing is, with this project i'm not trying to create a total monster, if i get a 2.5 lump with circa 300bhp then i feel i'd need to uprate brakes/suspension etc aswell, i just don't want to spend thousands and thousands on her, what i want is 200-230bhp, and if this is attainable without using a 2.5 lump or machining ports then i won't do that, i certainly dont want to cut corners but i also don't want to spend time and money on things that aren't required, plus i can always upgrade if i'm not happy at a later date :D
As for a turbo i realise how many dodgy ones there must be about second hand, luckily i have quite a few friends who like their cossies etc and i know of a good t34 thats a possibility, would this be seriously laggy?
Also does anyone know what the cam situation would be? is it worth using a 2.5? would it make any worthwhile difference?
I'll PM you Ant regarding the Megasquirt... :twisted:
Turbo-Brown
Boost Junkie
Post Mon Aug 07, 2006 11:01 pm
How long's the stroke on the 2 litre?
Be great to make a high revving turbo M20 :)
Reckon that 200bhp on a relatively low boost setup should be easilt attainable. It's about a 53% increase over standard, but I managed 54% with 7psi
I reckon you should go for it, and if you wanna upgrade to the 2.5 later on, you've got most of the ground work covered :)
WillG
Post Mon Aug 07, 2006 11:24 pm
short , its 66mm stroke on B20 , 75mm or near on B23/25 and stroker is 81mm
Toby_Unna
Boost Junkie
Post Mon Aug 07, 2006 11:27 pm
I think it's a great idea, use the 2.0 :D
it should make a really nice sweet engine, and every other 2.5 you hear about seems to have a cracked cylinder head. it's not all about power!
i'd also say go turbo rather than SC, the feeling of power building as it spools is great.
buster
Post Tue Aug 08, 2006 11:36 am
should be less chance of head gasket failure due to the fact that the 320 has smaller bores = wider gasket around the bores.More contact ,less chance of it blowing out.
dan_emaps
Post Tue Aug 08, 2006 6:54 pm
rarrr! it seems theres some advantages to keeping the 2.0 then!
Getting the ball rolling already, One of the Ford boys has managed to source me a Cosworth turbo for £70 :D he just needs to check it for play, but knows the seals are good.
Also definately going for megasquirt and it seems the Volvo 960 Turbo intercooler is the one to go for, so will source one of these when i can find one!!
Toby... how are you fixed for manufacturing another Manifold? would you make another if the money was right or have you had enough of welding for abit? lol :mad:
fuzzy
Post Tue Aug 08, 2006 7:45 pm
i use the t34 on mine and its not laggy,boost comes in at about 1400 rpm.id have doubts on a £70 turbo though but good luck 8)
dan_emaps
Post Tue Aug 08, 2006 8:23 pm
lol so would i normally but its from a trusted friend so if he says its good then i'll get it, it's cheap enough not to be too dissapointed if something happened to be amiss anyway :)
Turbo-Brown
Boost Junkie
Post Tue Aug 08, 2006 10:24 pm
Seems to be a bit hit and miss with second hand turbos doesn't it. We paid about £100 for a T25 from a 200sx for my mates car which has tonnes of slop in the shaft. I paid £200 for the turbos on mine and they turned out to be almost brand new!
dan_emaps
Post Wed Aug 09, 2006 12:37 pm
Turbos... who'd have them eh :P
Ok so the bits i'm still unsure on, Injectors, did you guys with charged 2.5s uprate them? should i need to?
325 cam, do we know if this will fit in the 2.0 no probs and if so, if is worth it?
Cooling fan - I imagine the I/C will mean i have to remove the viscous fan to fit it in, is an electric front mount fan the way forward?
Headgasket, someone advised fitting a metal one above i think, is this needed and how much/where from?
Ant
Retired Team Member
Retired Team Member
Post Wed Aug 09, 2006 1:17 pm
for the b20 some 30# inj will suffice, or some 19#(M30 units) with a 4 bar base rate on the regulator
I still have my viscous fan in place, as does Fozzy and Alex
H/gasket can stay, I doubt you'll push that as buster has already explained
Some 12.9 headbolts would be an idea though
leave the b20 cam in there Dan, lower duration, less overlap= great for FI
HTH
dan_emaps
Post Wed Aug 09, 2006 6:35 pm
Excellent, do you have any pics showing how your I/C is fitted?
Also can you supply the head bolts Ant?
Would i need to buy a different regulator for m30 injectors then? sorry guys, i am a total novice here :oops:
Pleased about the cam and h/g :cool:
