raising sport
elf
Post Sun Aug 06, 2006 8:17 pm
hope this is in the right section.
i need to raise the susspension on my car by 40mm all round
but not with standard springs want somthing a bit stiffer.
got eibach lowering springs already 35 drop front 30 back.
does anybody know if i can get similler stiff springs.
please dont ask me why. all will be revealed when done.
Post Sun Aug 06, 2006 8:33 pm
m-tech springs? maybe for a cab or touring? these are slightly stiffer on the rear for the extra weight, but i think the fronts are the same.
They are quite hard and will raise the car 20mm or so
hth
elf
Post Sun Aug 06, 2006 9:14 pm
Simon13 wrote:m-tech springs? maybe for a cab or touring? these are slightly stiffer on the rear for the extra weight, but i think the fronts are the same.
hth
thanks but realy do need 40mm
do any other bmw or simmiler springs fit
Adammcf
Post Sun Aug 06, 2006 9:23 pm
I dont know of anything uprated at the standard ride height.
m3ben05
Post Sun Aug 06, 2006 9:26 pm
H&R did some race spec gear for the M3 that was standard height. Not sure if they did anything like that for the 325, may be worth finding out tho mate.
elf
Post Sun Aug 06, 2006 9:28 pm
m3ben05 wrote:H&R did some race spec gear for the M3 that was standard height. Not sure if they did anything like that for the 325, may be worth finding out tho mate.
cheers ben got aphone no to enquire
m3ben05
Post Sun Aug 06, 2006 9:29 pm
Sorry but no, im sure if you google H&R you can find their number
elf
Post Sun Aug 06, 2006 9:36 pm
m3ben05 wrote:Sorry but no, im sure if you google H&R you can find their number
cheers ben i,l have a browse
