Can anyone pls help.. got H plate 320i and have a mindbendingly anoying cutting out prob. I've changed/elliminated the following so far:
Air flow meter, blue/brown coolent temp sensors, idle valve, ECU and fuel pump. Can't see anything obvious like frayed wires anywhere. It starts up ok from cold, runs till just about working temp, then just gives up the ghost. Will start back up ok (but not always straight away, sometimes not till after 5 - 10 mins before will start again). It always starts fine from cold. When it does cut out, it could be on a straight or a corner, but not one necessarily or the other. It will run again ok, but will cut out once again. I'm just about at the end of my tether, and am considering killing it, which would be a shame, because when it does run, its a belter of a little motor as you guys know they are.
Thanks for any help or advice in advance you guys may be able to give me.
Kev
P.S. All three relays within the fuel relays box on passenger side of engine bay have been checked - all ok.
