should i cut holes in the back shelf or not ?
andrewpany2002
Post Fri Aug 04, 2006 9:55 pm
hey, i recently bought 2 subwoofers and i put them in my boot and i was quite dissapointed with sound coming into the cabin, i was thinking of cutting 6 x 9 holes in the back shelf and the metal underneath it and then covering them with a 6 x 9 speaker grills to let more bass into the cabin, do you think it would make much difference or is there no point ruining the shelf, can anyone help ?
thanx :)
323i_rare
Post Sat Aug 05, 2006 12:02 am
The metal is there for a reason, strength. Cut it at your own risk.
Why not get a jack and jam the speaker against the back of the back seat?
stevetigger
Post Sat Aug 05, 2006 12:22 am
Don't do it!
:roll:
jon_pure_british
Post Sat Aug 05, 2006 12:23 am
my friend has a sub in his boot, and it sounds really good. either try a very powerful amp or if you are thinking along the lines of 6x9's you can purchase spacers so you can fit 6x9's, ive got spacers for mine, and it seems to work fine.
is your amp switch to hp or lp?
Clacton-On-Sea
Essex
Cotty
Hartge Crew
Post Sat Aug 05, 2006 10:20 am
The only thing you can remove metal wise is the ski hatch, in the boot remove the cardboard back of the seat and you will see an oval hole in the middle which is loosly tacked in. Remove that only.
kam325itouring
Post Sat Aug 05, 2006 10:24 am
yeap ski hatch only!!!! i fitted a 12" infinity running off a 600w west coast amp in my mates car it pounds!!!!! it sounds like you are either not driving the subs enough (amp too small) or the settings are wrong.....
dmaxfield
Post Sat Aug 05, 2006 3:15 pm
there are better options than cutting away your car that is sacrilage
delphini
Post Sat Aug 05, 2006 9:59 pm
no cutting i would leave it alone .....2 12's in the trunk and you'll see that there's no need to cut anything turn the box to direct your speakers towards the cabin and your set , my 1000 watt amp does the job in my cabby. :cool:
WerkdE30
Post Sun Aug 06, 2006 3:03 am
u can get spacers to fit 6x9 speakers. do not cut your parcel shelf.
mic1
Post Sun Aug 06, 2006 12:51 pm
in last months mag someone made a sub housing and aimed 2 subs at a 45" angle thru the rear arm rest so when thats folded down the bass comes thru.... ive thought of the 6x9 holes but debating how shit 6x9's in boxes on the parcel shelf would look :D
TW166Y
Post Sun Aug 06, 2006 5:09 pm
i heard of a bloke who cut out the metal frame to put subs in and eventually the car started to cave in on itself! doors would'nt shut etc... dont do it mate, 2 subs with a good amp is plenty in the boot! :cool:
Saying goodbye to 4-pot wrongness
