Hi Guys, i know this has probably been covered to death in other threads but im struggling to find a definitive answer.
I own a mint 320i touring AUTO and im wondering if a throttle body swap is worthwhile in terms of a performance upgrade?
Ive been offered a 325 t.body but the seller has also said its worth swapping the inlet manifold from the 325 at the same time??
Id really like to know the pro's and con's of doing this swap . Most importantly my engine is a low milage example im planning on running for a good couple of years with no probs if possible, and im wondering if im gonna just open a can of worms?......
p.s. what airfilter should i go for!?? just a panel swap?
Throttle Body and Inlet Manifold swap, 320-325
fowler
- Boost Junkie
doit get the 325 inlet and throttle did this on my cab when it was a 320 it just gives the car more reponse and a bit more grunt as the 320 are gutless
air filter dont bother witha panel dont do shite. geta nice hifllow air fliter green stuff piper cros somethin like that and get a heat sheild made then i wanted more power an threw in a 325 best decision i ever made
cheers
Ben
cheers
Ben
EX A-Tech Workshop bitch !!!
gone but not forgotten
Brodie320
cheers.
droppin a 325 in right now isnt an option for me, if my head blows ill consider it.
i actually like the performance of a 320, might not be blistering but has nice torque feel and kicks off at 4k RPM.
are any further modifications needed when fittin t/b and i/m in order for it to all work perfect or is it a straight no nonsense swap?
Brodie320
nice one Argos,
thats given me a bit more peace of mind. You reckon a zone chip? (this bit is goin to sound daft) do you mean open the ports on the 320 head? Its just i was hoping to go back to standard trim if unhappy with the results and for resale purposes.
Quaser
Yep - open up the ports on the head as the i/m will have bigger ports then the head does.
Im sure i told you this when i saw you (except the chip bit!) best bit it that it looks standard under the bonnet!
So, do you want it then?
Q
Q
dazleeds
- old skool raver
youll be happy with result mateBrodie320 wrote:nice one Argos,
its the best mod ya can do to a 320i imo
Daz
www.oldskoolfantasy.co.uk
Brodie320
I am interested Quaser. Whats ur best price for the pair?
Theo
Can do you the pair for £60 if thats any help Brodie, £95 with those other bits we discussed before (although you might as well collect this lot)
Quaser
Sounds like £60 is the going rate!
