Hc Emissions
Danny06
Ok peeps i need help big time, I took my car (bmw 325i sport) till get the air flow set and emission(hc & co) set 2day and my Hc is sittin at 2910ppm and needs till be 1200ppm or less for mot, we tryed every thing and cant seem till bring it down!..Has any1 had this problem before? Dont no if this has any effect but the car has a polished and gas flowed head along with a high lift cam!! Need thes emissions down big time for mot.... Any help please
Ant
- Retired Team Member
high HC normally points to a timing issue, if the valve clearances are set incorrectly , this can casue issues too
what was the idle CO mix ? if it was lower than 1.3 by some margin I'd suggest upping to around that figure and seeing if the HC drops off accordingly.
I assume you've no silly FSE "power valve " wrongness fitted, nor oversized injetcors etc etc ?
Email FTW
Danny06
The co mix woz set at 2.010%vol we tryd dropin the co and uppin it but lowested we got the hc till woz bot 2400
There is none of them valves that im aware of and same with the injectors just wot i have said above
regards Danny
Danny06
bump
regards Danny
Jon_Bmw
- Dangerous when thinking
Can't remember off the top of my head, but an exhaust leak pushes one of the values up, possible CO actually. Maybe worth a look anyway?
Danny06
the co is siting fine!!
regards Danny
stuartgallafant
BMW_YARD
Danny06
naw didnt cheek them as it woz till do with the air flow and have it running/idleing nicely now
regards Danny
