320 ECU on 325?
bimmaman
Post Tue Aug 01, 2006 10:46 pm
Hey people,
I have recently had a new engine fitted in my 316, but what is weird is that although it is a 2.5 (M20), it has the ECU from a 320... The car we took the engine from was originally a 320, and the previous owner had obviously fitted this engine.
I have had no problems with the engine whatsoever, so is having the wrong ECU serious? Would this be the cause of my electric windows/sunroof only working when I open the door??
Weird or what!? :mad:
blingsta
Boost Junkie
Post Tue Aug 01, 2006 11:11 pm
your windows would only work when the door is open anyway (without ignition)
cass1_5503
Post Tue Aug 01, 2006 11:26 pm
i had a similar problem with my old 316i with the windows if its with the ignition on and they still dont work check 1 of the relays behind the glovebox i think it is 1 of these that controls the windows well it worked on my car anyway hope this helps
Post Tue Aug 01, 2006 11:30 pm
The only difference between a 320 and 325 ECU is the chip. If this has been changed for a 325 one, or a performance 325 chip then it will be fine. Otherwise, the engine will not be running properly.
Window problem will either be fuse 17 blown, or, if the mirrors don't work either, a problem with the wire that goes to the smallest terminal on the starter motor.
bimmaman
Post Wed Aug 02, 2006 2:15 pm
Cheers guys...
I've checked fuse 17, and its fine... checked the wires on the starter motor, pulled them off, and put them back on again... Sat in my car, turned the ignition on, with doors closed, and the windows worked!!! :D
Started the engine, and they don't work again :?
Switched off, pulled wires, plugged em on again, and the windows work again, right up till I start the engine, then it goes back to only working when the doors are open... :mad:
Whats going on??
bimmaman
Post Thu Aug 03, 2006 1:10 pm
Sorry to be a PITA, but can anyone help?
Quaser
Post Thu Aug 03, 2006 11:35 pm
which colour wire is it? is it theone at the top or the bottom?
maybe you have a break in the wire which is ok until the engine starts shaking
i think its the yellow wire - i have run a new one to behind the glovebox on my car and all works ok now!
i had the same problem on my cab!!
Q
bimmaman
Post Fri Aug 04, 2006 2:40 pm
hmm. I took both those spade connectors off, and put them back on again. Which wire is the yellow one? I am colour blind!!! :mad:
Post Fri Aug 04, 2006 9:59 pm
On all the E30s I've worked on the starter control wire has been black/yellow, and the unloader relay wire has been green/black. Also, the connections have been by ring terminals, not spade connectors.
bimmaman
Post Sat Aug 05, 2006 12:25 am
So is this simply an earth problem? If so, which of the above terminals should I connect to earth? Or are my relays faulty?
One other thing, my offside rear indicator bulb seems to keep blowing... is this connected someway?
Post Sat Aug 05, 2006 12:30 am
Niether of the terminals connect to earth. The starter motor earth connection is through its mounting bolts.
The starter motor terminal to which the black/green connects is effectively an earth terminal, except when the starter is operating, when it becomes 12V+.
bimmaman
Post Sat Aug 05, 2006 12:36 am
Quaser wrote:i think its the yellow wire - i have run a new one to behind the glovebox on my car and all works ok now!
Ok, please excuse my ignorance... So I should connect a wire, where?
What do I need to do to fix this annoyance?
Post Sat Aug 05, 2006 9:39 am
Got to find out why your starter motor is different from ones I've seen first, and identify the colours of those wires.
