help with steering + brakes
sam320i
Post Wed Aug 02, 2006 5:56 pm
hi boys and gals...... just put some new wheels on my 320i and now wne i go round corners full lock (left or right) i canhear and feel a knocking coming from both sides!! nothing is rubbing cos i've checked and the brakes are making a grinding noise but there pretty new and look ok?? any help would be great as i gotta drive upto santa pod at the end of the week.
Sam :cool:
handpaper
Post Wed Aug 02, 2006 8:12 pm
Wheel bolts torqued correctly?
What wheels are/were they?
sam320i
Post Thu Aug 03, 2006 10:49 am
they are valbrem wheels not sure which model but came off a 325i cab, i now know that the lower balljoint is fu%"*d now so would that be whats causing the knocking??? :x
Chris-W
Post Thu Aug 03, 2006 10:52 am
That would definitely cause the knocking you describe. Also shakes under braking.
sam320i
Post Thu Aug 03, 2006 10:54 am
yea a bit mate i know one of the wheels has a slight buckle which would make it shudder a bit! cant figure out why the bloody brakes are grinding tho they're only about 3 months lod and look alright??
Chris-W
Post Thu Aug 03, 2006 11:07 am
Doe they grind all the time? If so it's likely just a backing plate is making contact with a disc.
Martinaston
Post Thu Aug 03, 2006 12:53 pm
"just the backing plate making contact" :mad:
then that would surgest your wheel bearing is shagged and if its not then fitting a buckled wheel will soon fuck it up.
If you didn't have the rubbing before you changed the wheels what do you think it could be :poke:
Check the steering rod and the inner edge of the rim.
There is NO nucleus.
Chris-W
Post Thu Aug 03, 2006 1:05 pm
Wouldn't be the first time a backing plate has been bent a bit when wheels are changed.
