Imagine if you will the sound off...(Det info)
JAMZ
Post Tue Aug 01, 2006 8:14 pm
A cone filter heatshield made outa ally that is wrapped round that and the AFm but isnt fastened down but the noise it would make as it vibrated against the chassis when driving...
That is what i have continioulsy..sound like Det?
If anyone can find or get me a clip/Wav of detonation/pinking that would be great BTW
i took said shield off and stuck it in the boot..still had noise and it doenst get louder as RPM's increase and it doenst just happen under boost..infact the only time i CANT hear it is if i take my foot of the Gas...any level of throttle and i get this noise..faint but its there
Does it sound like nails rattling around in a tin..yep it prolly does but the symtpons/times of it happening are different to what ive read with only under boost or high RPM's etc
So while on the phone to Jon_bmw i thought id adjust the boost and knocked it down to 5psi and still had the noise... can that really be Det with them symtpons and at that PSI?
Ant
Retired Team Member
Retired Team Member
Post Tue Aug 01, 2006 8:20 pm
if she rattles under heavy LOAD ( forget boost/rpms etc etc) its almost defo some Det creeping in
nails in a tin is a good way to desribe the noise, short of hearing it in the flesh, cant say 100% either way Jamz, Iain may be worth asking , or the guys @ E-Tech ?
JAMZ
Post Tue Aug 01, 2006 8:28 pm
Hi Ant... thats the thing m8 as i said above its not just under load bud... as soon as i got any type of gas going in i hear it...if i take my foot off the gas and coast i cant hear it so does that sound like Det...doesnt to me from ive read, cant hear it on idle either when reving not that that makes any diff
Turbo-Brown
Boost Junkie
Post Tue Aug 01, 2006 9:02 pm
Yeah, you wouldn't be putting any load on it just revving so it'd be less likely to occur.
Does it get louder/more intense with more throttle?
JAMZ
Post Tue Aug 01, 2006 9:08 pm
Doesnt seem to.. certainly not louder
JAMZ
Post Wed Aug 02, 2006 10:40 am
So how am i going to get round this as i dont know what im looking for?
hopefully Jon will be able to get down here and take a look,sure he will know straight away...5psi with a nice IC flow and still have Det is ludicruis so im hoping what im hearing isnt that.
im looking at doing a conpression test too ASAP as i think its the stem seals gone and what else they find while there down there..so sorting this Det problem out now is parramount.
Jon_Bmw
Dangerous when thinking
Post Wed Aug 02, 2006 11:06 am
Carl, just woke up :o
Answered your pm.
Top thing to check i think would be the vaccum pipes to the boost gauge, FPR and the Vortech. Check the boost one carefully as its routed near the turbo and may have got burnt!
JAMZ
Post Wed Aug 02, 2006 11:12 am
Would that cause Det?....
Checked em yesterday... no leaks,cracks or holes
Wouldnt explain the poring of blue smoke when cold m8
Jon_Bmw
Post Wed Aug 02, 2006 11:16 am
No but we are talking about two different problems here, this thread was devoted to supposed DET
JAMZ
Post Wed Aug 02, 2006 11:20 am
I got to take the car down somewhere in a mo to hopefully get a test done or at least pick the tester up...before i got im going to adjust the boost to next to nothing 1-2psi if poss plus il check all pipes/hoses again once i can see what im doing ..*cough cough
