LOWERED 325iSport PICS Here !!!
60/40 is the perfect drop imo
60mm on the front!
cupkit for u my man!
60mm on the front!
MadE30mike
Is the H&R cup kit a good buy then? Takeit it handles better lowerd more at the front? wont this make the arse look high???
no it looks perfect 60mm rear is where all the problems start with exhuausts and speed humps etc. The Back then looks lower than the front too if u ask me
for the money cupkit cannot be beaten, it will give the same ride as an m-tech car nearly and handle much better!
60mm rear means tyres wearing out in 5000 miles too which ain't funny on a daily drive car.
heres my old one on flat ground 60/40, ended up lower once the springs had settled
but here is the same car on 35mm drop, which is alot more daily drive friendly and still looks low
Was in track slag mode here!
BIGJO
It might look a little higher but it will probably need to be that little bit less on the mm drop because when those rear wheels light up, the ass drops! Now you can't have the rear wheels touching their arches when doing some speed! Especially when you live in a bumpy town as that will cost!
Jo.
Jo.
MadE30mike
I think you have just convinced me
Guess wot im buyin on pay day lol
Will this make the car spin up easier especially in the dry?(Donuts,drifts etc) or will it make it grip more?
drifting is all about technique. 325's go in the dry or wet it's how u drive them
BIGJO
It looks lower because the rear arch is positioned lower than the front (for example in Simon's first picture). I have to admit, i do love driving low at 60's all round but do feel the rear could do with a raise of 20mm (-40). Especially when you have people in the back
Jo.
Jo.
MadE30mike
So say u were sitting on the spot in 1st gear in the dry n u revd it up n ping the clutch the rear wheels shud light up eh?
BIGJO
Shizzle my Nizzle! Guaranteed! Then you'll be thankful you had a perfect 60/40 drop!
Jo.
Jo.
BIGJO
Trust me & when the LSD kicks in.............no time for wheel spinning it's gone!!!
Jo.
Jo.
1st and 2nd but only with 15bbs on. When i had my 16x8 alpinas on the back it was a job to get the rears going in the wet. But i built my old sport to handle well on tracks and roads not drift!
i had rubbing issues on mine with no people in the car! but my alpina 8j;s on the back and a wide offset which didn't help. Was fine with bbs. I could take 2 light people eg bitches!
used to rub quite bad on full boot through the gears each time u changed as the cupkit springs are soft on the back, helps the rear dig in and get traction i found.
MadE30mike
Sorry if this is all soundin abit stupid but how do you know when the LSD is doin its job?
My Car is totaly standard at the moment n it def has a LSD n its great in the wet but it doesnt seem up4 it when its dry,rev it up n pop the clutch n it just grips or clutch slips or sumthin.
I can get it to go no problem if im already rolling its only when its from a standstill im having this problem eh
Is this because its on standard suspention mayb?
BIGJO
If it's a Sport which it is then the standard kit is still lush, especially with the 16 BBS's!
When you're in the dry, how does it feel when you put your foot down? LSD stops all the spinning out & reduces it to a minimum! Also when you spin out on bends it well sharp to bring it back under control because of the LSD
Jo.
Jo.
the cluthc packs in your diff could be worn out, they only have a 10hr lock up life time, so if everyone who owned it before u was a sideways hero it could be worn
jack he up one side on the rear, car in neutral, handbrake off and see if the wheel spins. It shouldn't move or if it does very stiff. this means u have a slipper. If it spins easily then it's not
or just spin her up in 1st and see if u leave TWO black marks for each wheel! open diff will only leave one.
MadE30mike
Iv already jacked it up n the wheel does not mave, it has a LSD.
Thats what im tryin to say! I get NO black marks!
i wouldn't worry then. If your that intent on spinning the wheels up and trying to be a sideways hero then it's practice my man! not an easy art to master by no means
MadE30mike
Iv had the thing sideways plenty times n had a few scary high speed incidents to
, this is my only problem with the car n i dont know whether sumthin is fukd or theyr all lyk this in standard form?
It cud be many things i supose , Good Tyres,S#@t Clutch,standard suspention etc
just wondering if any1 else has had this problem
MadE30mike
I WANT TWO BLACK LINES
LOL
ric325i
guys back to suspension just quick i have bought a jemax set -40mm all round and was wondering how long it takes to bed the springs in and get it low?
plan to do the change over this weekend.
i decided to go for the 40 drop as i dont have the balls for -60 and dont think its practical.
BIGJO
The LSD puts the spinning to a minimum & puts you on the road to race. If you're getting no black marks that must surely mean that your LSD is in correct working order. I'm not that kind of person that frequently spins my rears & then produces a burnout with black marks (as that cannot be good on the engine if you're red lining it) but when i pull away quick i mean QUICK (in the dry) you will hardly see me spin my wheels & i'll leave very faint black marks!
Jo.
Jo.
bmwe30mtech
Call me boring, (even though i have had a lot of fun and sideways in the rain in my M40!) but does it not ruin the cars just thrashing them in the dry
. I have tried my 1.8 in the dry and it spins slightly, but i barely ever do it. Can the sports take the abuse?!
it puts enormous strain on your suspension and particularly the cars drive train
mike your car probably has 18 year old suspension bushes which will add an air of unpredictability to the handling.
sports will break the back end more sudden compared to an open diff car when u can feel the back go about an hour before it does! not o with an LSD, but when it goes with an LSD the slides are easier to control imo
MadE30mike
Iv only tryd it twice n i dont normalydo burnouts n stuff im mearly just testing it to see if everything is in perfect working order.Iv seen videos of other sports spining up no problem in the dry n sitting on the spot doing burnouts, i just want to know whats wrong with mine thats all, i dont intend to go through a set of tyres every weekend lol
ric325i
needs more power! all jap drifters use LSD's for drifting.
but the cars are set up differently and with lots more power!
the LSD is the best for drifting but the main thing a LSD is for is to stop spinning, get the power across both wheel and get the power down.
i would love an lsd to stop the inside wheel from spinning and make better use of the power.
just keep practicing there has to be a way to make a few strips...........maybe hold brakes slightly?
seen it done but couldnt bring myself to do it.
BIGJO
The straight 6 can handle the red line! With a nice clutch the transmission is amazing, the gearbox can handle a lot of power! It obviously isn't good if you continue red lining it but trust me, it can handle it! The LSD will hardly ever go wrong (unless you forget to check the oil)
Pulling away with a load of wheel spins isn't really me! But you know when the LSD works! I've been driving in Brighton & it's been wet......................the car dragged me across this roundabout it was GREAT!
The Sport can take much abuse, take it to 5 1/2k revs no problem............ 6k still no problem! Wouldn't really recommend going further than 6 1/2k unless you can avoid/prevent it from hitting the limiter because THAT'S NOT GOOD!
As long as you're well disciplined on the road on most occassions & occasionally go mad it's all good! But continuous red lining isn't good, trust me! Valves start snapping & sh*t! Starts getting expensive as you can't just replace the uno with a new valve, if your driving a Sport you'll need the whole set (12). Can get worse than that as well!
Jo.
Jo.
MadE30mike
So would you say its easier to hold(control) a slide(drift) in the dry or in the wet?
BIGJO
With the LSD & suspension set up the cars amazing to handle! The standard suspension you have on the car is probably on its way out, if the car's on a H plate for example, thats a set of 16 year old suspension. You won't be doing yourself any favours driving the car with the standard suspension, not if it's that old!
Changing the suspension to something better for example the H&R Kit or Koni's will let you handle the car so much better! You will not know how beneficial it is to the car unless you replace the suspension. It's not good to play too much in the wet as with the LSD, when it kicks in it's hard to control! Harder than it would be in the dry, BUT it's all good fun!
Jo.
Jo.
H35-IAN
if you can drive and theres just about enuff power there! then you can drift anything in the dry or wet! 1000% agreedSimon13 wrote:drifting is all about technique. 325's go in the dry or wet it's how u drive them
i can drift a 320i in the dry with a slipper nps my 325i tech 1 is the best sport ive had to drift in the dry it locks so nice....
bmw 328i sport e36
MadE30mike
Yeh thats the info i was looking for cheers Jo.
I think if i got a shot of a car without a LSD id be able to see the differance i supose eh
MadE30mike
Can u replace the plates in the diff? is this a hard job?
BIGJO
Yes mate, you would easily be able to see & feel the difference. I had a 325i SE which was tuned up to the bullocks without LSD, & trust me that was quick! It would spin out so easily! Couldn't afford the LSD as i was only 18 & then the LSD was going for about £450-£500 then. However, like i said i sold the SE & got a Sport for the same amount when i was 19, wasn't as quick but it didn't take me long to start working on it!
My point is, when i had the SE i knew there was nothing to save me apart from my reaction towards the steering wheel when the car spins out! That's how i used to think & therefore anticipate the spin-out!
In the Sport however, you know the LSD is there & will prevent you in making a mess of yourself!
Don't suppose the LSD is making any noises is it? Has anyone that sits in the back or as a passanger said anything about any noises?
Jo.
Jo.
MadE30mike
No the diff is totally sillent no whinning nocking noises nuthin, its only dun 102K aswell eh n its been service regularly by BMW until 2004, its the cleanest sport iv ever seen btw. sorry dont mean to sound big headed or that but iv never seen a cleaner 1 than mine eh
BIGJO
That's cool! I'm happy that you got a minter! There needs to be more mint Sport's out there!
Think your LSD is fine then fella, if you get a chance to drive a 325i without LSD you should take that chance like a rat up a drain pipe!
OR if you ever get a chance in an E30 M3 where you can turn it on & off!
You'll definately be able to tell the difference. How much power is your Sport running just out of interest?
Jo.
Jo.
MadE30mike
I could not tel u tbh never had it on a rollin road eh, its totaly standard anyway so wont be anythin special, this is prob half my problem. the other half is prob that im scared to break anythin. it doesnt seem half as sore on the car when the ground is wet eh
bmwe30mtech
If your sport is a minter, then leave it standard, maintina it and dont thrash it in the dryMadE30mike wrote:I could not tel u tbh never had it on a rollin road eh, its totaly standard anyway so wont be anythin special, this is prob half my problem. the other half is prob that im scared to break anythin. it doesnt seem half as sore on the car when the ground is wet eh
