M20 Cylinder Heads. Is There A Difference?
maxfield
Why not get a 325 inlet instead of going through all the trouble. Plus you wouldn't get any gains anyway. Would it increase air flow?
DelaneyG
you can get a tool which goes on the end of a drill and push it through, its kinda like a pipe cleaner
DelaneyG
gettin the 325 manifolds the best bet
but if you ported and polised the 320 manifold it would make a difference cos the air can flow more smoothly but you have to do the lot to really get the best results
[/quote]
[/quote]
Beastly_Bavarian_Beauty
Where can you get one of these porting/polishing extension (pipe-cleaner like) tools from? Manufacturer names? Places that stock them? Prices? Etc?
Oh yeah... and does this tool fix onto the end of a drill? Like a flexible extension? Any web links to an example would be good too guys. Thanks.
maxfield
Why not polish the TB aswell
DelaneyG
il find out about the tool
youd wana leave the throttle body as it is, they are already smoothed anymore and they wouldnt work properly
Bravo. Good advice ARGOS. Actually bought a tent at the weekend from Argos also, cut down from £79.99 to £39.99. Seeming to be an amazing place. Great deals and amazing advice. lol
Turbo-Brown
- Boost Junkie
Eh?maxfield wrote:I'd guess you woudl lose power all through the rev range as there is no advantage of a smaller inlet.
That's not true at all!
A smaller diameter tract should yeild more low end torque as the air speed approaching the engine will be greater in the smaller pipe than it would be in the larger pipe.
Because the air speed is greater, the air approaching the engine has more momentum and as a result of that: more of it goes in, to which the corresponding amount of fuel can be added leading to a bigger bang and thus more power.
However, this can of course become restrictive after a point.
Don't assume that bigger must be better when it comes to the sizing of inlet systems!
- Homo Hair
no chance, it will lose to standard 320's when doneDelaneyG wrote:an itl be more than a 10 bhp gain when its all done
better off fitting the 325i cam into a 320i head, bout the only thing that will be of use to you
Argos summed it up pretty nicely imo
- Homo Hair
dont fit a 320i inlet to a 325i total waste of time
also polishing it will achieve basically jack all, the air needs some turbulance to mix properly with the fuel
as argos says the 320i inlet cant be opened out enough for a 325i
i'm sure i said in this thread the same thing argos did. I guess some people don't read what i say which is nice
DelaneyG
What are you talking about? first off that comp ratio is for an m20 with a cat mine hasnt got one so its 9.4:1 2nd im incresing the comp ratio by taking 60 thousands of an inch off the head and 5 thounsands off the block 3rd im going to adjust all the ratios by calculting the cc of the combustion area and smoothing to suit it. "throttle response of a lawnmower" i think not luckily i am going to build this engine when i take my car off the road in sept so maybe youl see for yourself.Argos wrote:Fitting a 2.5 head to a 2 litre would acheive absolutely nothing. Sure, you have 2mm bigger inlet and exhaust valves but you'd drop the compression from an already miserable 8.8:1 to around 8.4:1 so you'd have the throttle response of a lawnmower - any power you'd gain from the bigger valves would be lost with the lower compression.
But a 2.5 head will fit a 2 litre and it'll run and drive okay althouigh the valve top piston cutout clearance is very, very tight. It's not a satisfactory job by any means. A 2 litre head will NOT fit a 2.5 of any desciption. Contrary to popular opinion there is actually very little difference in port size between the 2 litre and 325i heads but the top of the port is a slightly different shape. The reason the 320i is so fartless at low rpm is because the ports are too big causing slow gas speeds. At higher rpm the big ports should come into play but the small TB restricts it badly - a lose-lose situation.
The only mod worth doing to a 2 litre is fitting the 325i throttle body along with a chip. I've done this twice - the first time was by opening out a 320i inlet manifold which is sort of okay but there's not enough meat in the manifold to do it 100%. A far better solution is to fit the 325i inlet manifold complete. To do this you have to open out the inlet ports slightly which is easily done with a 325i inlet gasket as a template and a stone in an electric drill. The 325i manifold will then bolts straight on and the ports will match up. Combined with a chip I reckon this will find you 10 bhp and make a 320i much more lively.
Bigger valves = more air in more air out meaning better responce
Of course itl fit its the same engine!!
For a valve to hit piston youd would need an extreamely high lift cam.
Ports need to be big big and smooth smooth how can a big smooth port cause low gas flow?? are you mad theirs less restriction thats basic engine tuning
DelaneyG
Eh? why would you want turbulance? the idea is to get rid of turbulance if theres no turbulance you can get fuel in quicker it will mix better and you can get it out quicker so the engine can turn over quickerJhonno wrote:dont fit a 320i inlet to a 325i total waste of time
Smoother=Quicker=Faster!
but their is no point putting a 320 manifold ona 325
bigkev
so how does that explain why the bike that won the british supersport championship last year actually had the inlet ports decreased by 25% with epoxy resin
this is to give you more velocity into the cylinder which fills quicker and allows you to have a wilder cam timing (more overlap) as you dont get so much blow back through the inlet port the only thing that dictates flow really is the valve itself
DelaneyG
sorry mate i only work on cars i dont know a thing about bikes apart from they rev to 12000 an more in some mad cases!!
DelaneyG
yes and no, if the air can get to the valve quiker then that will increase the amount of flowthe only thing that dictates flow really is the valve itself
bigkev
bigkev
jmc330i
Everything on the exhaust side needs to be smooth to get the gases out quicker, but on the inlet side you want (to a certain extent) a rough surface to create turbulance, this helps the fuel mix with air to improve combustion.DelaneyG wrote:Eh? why would you want turbulance? the idea is to get rid of turbulance if theres no turbulance you can get fuel in quicker it will mix better and you can get it out quicker so the engine can turn over quickerJhonno wrote:dont fit a 320i inlet to a 325i total waste of time
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Turbo-Brown
- Boost Junkie
Interested to know why you think that, considering that the larger inlet area on 4v engines typically reduces gas speed and therefore low end torque when compared to 2v engines.Argos wrote:the faster it arrives at the valve, the more gets crammed in on one stroke. This is how four valve per cylinder technology came about.............
Note how Honda have an engine in their armada which uses only one of it's two inlet valves at low engine speeds so as to keep the gas speed and torque up.
Martinaston
So as a rough guess from all the comments what we realy need is a manifold with variable bores to keep the air speed constant throughout the rev range
Going back to a comment on page 2 of this thread,
Is there a difference between a 320 and 325 cam ?
There is NO nucleus.
jmc330i
Rover 827s have some sort of trick inlet manifold dont they?Martinaston wrote:So as a rough guess from all the comments what we realy need is a manifold with variable bores to keep the air speed constant throughout the rev range![]()
Im guessing its something to do with airflow.
There must be, putting the 2.5 cam into 2.0 makes a difference apparently.Going back to a comment on page 2 of this thread,
James
'91 325i Sport
'91 325i Sport
yeah but it's not a straight forward swap is it?
thats why 4v cars typically have less torque low down than 2v
i've noticed it slightly between 24v 2.5's and 12v 2.5's E30's that i have driven
jmc330i
What the 2.5 cam into the 2.0? I dont know Ive not done it, but I was at college with a guy who did and his 320i went pretty wellSimon13 wrote:yeah but it's not a straight forward swap is it?
I noticed that when I had my 2.0 8v Cav. The 2.0 16v Cavs and my friends Astra Gsi only really pulled away once they got up the revs.thats why 4v cars typically have less torque low down than 2v
James
'91 325i Sport
'91 325i Sport
jmc330i
Odd, I know for sure the guy I know fitted the 2.5 cam to his 2.0, plus the inlet and TB.Argos wrote: Putting a 2.5 cam into a 2 litre doesn't do anything apart from fuck up the idle. The profile and lift are pretty much the same but the timing isn't - the piston speed of a 2.5 is a lot faster than a 2 litre.
Is there anything else that could be changed to make it fit/work? Got me interested now as to what else he did to it and didnt tell us
James
'91 325i Sport
'91 325i Sport
Martinaston
I compared two cams alongside each other and didn't see any difference but i didn't check the overlap,
I'll have to have another look when i get a 325 out.
Argos whats this about an E34 M5 ?
- Homo Hair
DelaneyG please stop before you hurt yourself.. You obviously dont have an inkling on how engines work
Argos.. I i thought the 325i cam was higher lift than the 320i cam.. hence why temple320 i believe fitted one in his 2.7 with a 731 casting
as argos said the whole 8v's having more bottom end torque thing is still based very much on the golf gti's of the 80's... the xe lump is a torquey bugger from 1000rpm to redline it is more than likely a seat of the pants thing as they lack top end the bottom end feels torquier
airflow into a 16v head gets split in 2 on each port to go to each valve so air speed is pretty much maintained
