"Sport" Gearboxes versus non-Sport Gearboxes
LowLevel
Post Sat Jul 22, 2006 7:18 pm
Who has had both?
Are the Sport gearboxes really that much better?
What is a Sport gearbox like at track days?
What is the right diff ratio for a Sport gearbox? 3.25?
Thanks!
-AJ
Post Sat Jul 22, 2006 7:36 pm
3.91 is gonna be the one for track days..
Sport box will be better out of low speed corners.. its difficult tho, different circuits will suit different ratio boxes hence why proper race cars have adjustable ratio boxes..
DieselMeister
Post Sat Jul 22, 2006 7:38 pm
I've driven a std 325 and its nice but the sport is more urgent. I think the diff is uber low at 3.91. Whats nice is that the interim gears are closed up - shifting from 4th to 5th is no longer a killer during accelerative bursts. All it needs is a sixth ratio to prolong the fun 8)
It's pretty much optimal so long as cruising economy isn't an issue (if so go buy a derv drinking mundano or something).
LowLevel
Post Sat Jul 22, 2006 7:54 pm
I have a 3.91 for my standard non-Sport gearbox --- should I run a lower ratio for a Sport gearbox? Like a 3.25? Or a 3.73?
I'm not going to change the diff just for track days --- and I will have to spend some time on the motorways, etc --- so help me pick a good flexible ratio!
Thanks,
-AJ
BMW_YARD
Post Sat Jul 22, 2006 8:03 pm
DieselMeister wrote:shifting from 4th to 5th is no longer a killer during accelerative bursts.
:mad:
4th and 5th ratios are the same in sport / non sport boxes
Post Sat Jul 22, 2006 8:09 pm
3.91 is fine on the motorway
3.25 is waaay to long
LowLevel
Post Sat Jul 22, 2006 8:11 pm
:mad:
I thought the non-Sport 'boxes have an overdriven 5th gear, while the Sport 'boxes have a 1:1 5th gear?
Here are the ratios I have found --- are these correct?
Gear Ratios / Gear
Standard Close Ratio
3.83 3.72
2.20 2.40
1.40 1.77
1.00 1.26
0.81 1.00
-AJ
Post Sat Jul 22, 2006 8:13 pm
sport boxes have the same 4th and 5th gear as the non sport
5th is 0.81 or summat..
e36 boxes are 1:1
DieselMeister
Post Sat Jul 22, 2006 8:21 pm
This may be but the sport box plus 3.91 diff makes for a different driving experience imo.
I'd like 24 valves to go with that gearing to make even more of it :)
LowLevel
Post Sat Jul 22, 2006 8:22 pm
Jhonno wrote:sport boxes have the same 4th and 5th gear as the non sport
e36 boxes are 1:1
As I understand it, and maybe I'm wrong, there are:
- Standard 5-speeds w/ overdriven 5th gear (0.81:1)
- Close Ratio 5-speeds, "Sport" 'boxes, all 5 gears are slightly higher than the gears in a Standard 'box, and a direct 5th gear (1:1)
- Dogleg CR 5-speeds, same ratios as Sport 'boxes
Where can I find the accurate info?
-AJ
LowLevel
Post Sat Jul 22, 2006 8:23 pm
DieselMeister wrote:This may be but the sport box plus 3.91 diff makes for a different driving experience imo.
What is your RPM / engine speed when you're doing 70mph w/ your 3.91 and Sport 'box?
-AJ
Andy335Touring
Post Sat Jul 22, 2006 8:28 pm
It's a bit confusing having these two threads on about the same thing but this should help, it's taken from the owners manual
LowLevel
Post Sat Jul 22, 2006 8:33 pm
Fantastic!
Thank you -- that's what I needed!
-AJ
DieselMeister
Post Sun Jul 23, 2006 10:52 am
80mph equates to around 3.5k rpm. A bit busy for a 2.5 litre but as its a bimmer straight six, it doesn't mind and sounds / goes absolutely fine.
Wind noise is the biggest problem for E30s, being shaped like the proverbial housebrick.
dav325i
Post Sat Jul 29, 2006 4:06 pm
whats the top speed for a sport? mine struggles to even show 140 on the clock :? thats with 17s fitted so not sure if will make much of difference :?
were as ive been in normal 325i that seems to pull past that no bother :?
mrLEE30
Post Sat Jul 29, 2006 4:53 pm
140 in a 325??? pull past that no bother??? sorry mate but dont think thats quite right. The factory quoted speed was only 135(actually 137) and those figures are normally optimistic, was your speedo in km/h?? :mad:
ianeire
Post Sat Jul 29, 2006 11:58 pm
Ive hit between 135 and 140 mph on the clock on 15's. How accurate my speedo is I dont know.
1990 Brilliantred 325i Sport
www.e30owners.com Irish e30
stevetigger
Post Sun Jul 30, 2006 12:12 am
135 is about right, I have had 7 "Sports" that was the average
mrLEE30
Post Sun Jul 30, 2006 9:52 am
you speedo will be about 7-10% out so an indicated 140 will be a more realistic 125-130. and the size of your rims (within reason) will not make a great deal of difference if your tyres have the correct aspect ratio. and of course it will depend on road conditions i.e the gradient, a 5-10mph head wind will take a great deal of top end speed off of a car as un-areodynamic as an E30. and if is hot then you can forget another couple of mph. even my Z3 coupe with the M54 3.0 engine struggles to make 230km/h in summer, but... my 1000cc mini (slightly modded)would reach all the way round to the IGN mark on the speedo down the southbound M6 hill near the Tickled Trout :D which by scale is about 105-110 mph!
Dav not saying you didn't see this speed but were the two road conditions the same? so many factors affect top end speed.
mrlee
Post Sun Jul 30, 2006 2:23 pm
sport box is better imo. but i would only use 3.64, 3.73 or 3.91 diffs whichever u prefer. 373 is the best of both worlds
LowLevel
Post Sun Jul 30, 2006 2:45 pm
For a track car, which diff would you choose? A 3.91?
-AJ
Post Sun Jul 30, 2006 2:55 pm
if it's a track car for using on UK's circuts i'd use 3.91 yes. All our tracks are short really and it will give the best acceleration.
i found 3.91 to fine round the ring also
M5pilot
Post Sun Jul 30, 2006 3:38 pm
Another vote for Sport gearbox.
Big difference when going from 2nd -3rd gear.
Sal
dav325i
Post Sun Jul 30, 2006 3:40 pm
well as i said it was only indicated on my speedo and i knew that isnt accurate.the road was the same long stretch of road.obv not excact same conditions as wasnt the same day but felt the normal 325i had a much better 5th gear :? maybe it was he had a standard exhaust and my one makes some noise at that speed :oops: .maybe just made it feel like the car wasnt trying as hard i dunno :?
dav325i
Post Sun Jul 30, 2006 3:42 pm
forgot to add this road was in germany :wink: :roll:
jonbuoy
Post Sun Jul 30, 2006 4:50 pm
dav325i wrote:well as i said it was only indicated on my speedo and i knew that isnt accurate.the road was the same long stretch of road.obv not excact same conditions as wasnt the same day but felt the normal 325i had a much better 5th gear :? maybe it was he had a standard exhaust and my one makes some noise at that speed :oops: .maybe just made it feel like the car wasnt trying as hard i dunno :?
The reason people do not believe you is because they do not know what can be achieved with changing ratio's of gearbox's and diff's.
With a 2.0L gearbox and a 3.25 LSD, my car did 130mph (Speedo reading) in 4th at 6000rpm!
She was doing 140mph in 5th at about 5500rpm!
The ratio's may have been changed mate, you never know :wink:
I changed the ratio of my diff on mine to 3.64, does about 130-135mph in 5th now LOL
