Bumper removal.
ian332isport
Guys,
How hard is it to remove the front and rear bumpers (Mtech2 kit).
I'm pretty sure the rear bumper is just the two big Torx bolts underneath, a couple of small self tappers underneath, and the whole thing just slides off backwards.
How about the front. Is that just as easy, or do you need to split the lower valence from the bumper ?
Ian.
Ian.
E30Adam
Blimey this is a first!!!
Firstly the rear bumper, as you say it's just the large 2 torx bolts. Make sure you smother them with WD40 or similar first. When I tried to remove mine, the head snapped off one of them so I've still not managed to get the rear bumper off!
The front bumper is the same but forst you have to take off the apron. Remove the fogs and unclip along the top of the apron , the sides are held on by little plastic plugs. I'd recommend buying new bolts for refitting the bumpers.
2.8 Litre M20 powered - Essen Sie meinen Staub biatch
Simon
There's a series of push clips behind the front valence too.
And yes that is a first...Ian asking a question!!
randomdave325
- Random E30 Nutta
you are right in how the rear comes off. tho i find it easier to undo the four 13mm nuts that hold the bumper shock mounts on. 3 are in the boot. 1 is underneath above the backbox (fun). the cages on the bumper for the torx bolts nuts snap and be well annoying
the front is by the 2 allen/torx bolts. from memory i think u have to remove the front spoiler first. 2 10mms in the side behind the w arch liner. be careful tho as these have been known to break out of the spoiler. the rest is clips. i'll pop outside to check fo defo if it has to come off. brb
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
'Turning money into noise'
randomdave325
- Random E30 Nutta
i'm pretty sure u don't have to take the fogs out adam. i never have.
the front apron defo has to come off to allow the bumper bolts to clear. just been outside with a torch!. 2 bolts and those black clips with the push through centres hold it on. the top is just clips. pull to release.
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
ian332isport
Cheers guys. You
I'll see if I can get the bumpers and the rest of the kit off tomorrow. No point paying good money for the bodyshop to remove it all.
I have allready got virtually every clip, screw and fastner for the bumpers and bodykit, so no probs there. The ETK is a wonderful thing
Cheers,
Ian.
Cheers,
Ian.
Davenotouring
Re: the front valance.
I bought one from BMW recently, it cam with loads and loads of screws and clips.
The front valance is held on by the clips (which you can see) which sit in the bottom of the bumper. The bolts round the side are a pain, you need to be careful, as mentioned above, the plastic on the valance can snap. There are three (I think) brackets underneath the valance which are bolted on. There are also lots of expanding rivets underneath. I think that's it. The fogs don't need to come out on mine.
This is all dependant on whether the Touring set-up is the same as the 2 door.
It sounds like the valance is more difficult to remove than the bumper.
BMW 328i Cab - Daily Slag
randomdave325
- Random E30 Nutta
incedently ian. whilst you're about. i get my m50 next week
what engine mounts did u use? e30 e36 e34 or something else. dean at grants used e30 ones with a 8 mm spacer on the o/s in his 2.8 conversion. looked a bit dodgy to me. fitted tho. and was the wiring too much fun. zionsville do a cd rom with the wiring diagram. is it worth getting. all the main wirings all to the ecu. the rest should only be ancillaries (shouldn't it?)
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
ian332isport
I used E28 M5 mounts on mine, and no spacers.reardiffraver wrote:incedently ian. whilst you're about. i get my m50 next week![]()
BMW part numbers:
11 81 1 128 932 - Left
11 81 2 225 201 - Right
I found the wiring easy, but it helps being an electronics Engineer. I have never seen the Zionsville CD, but by all accounts, its a waste of money.
I'm sure I can help with any wiring questions you have. What model/year E30 are you using, and what model/year did the M50 come from ?
Ian.
randomdave325
- Random E30 Nutta
aha. i think e28 was the only one i missed from my list and that makes perfect sense. my car is an 88 325se (sig pic) and the lump is coming from a 92 e34 525se. i though that would be the best age as after 94 they have the coded key issue. you would of dealt with this on yours. fair shout as that is supposed to be a mission. but it should be loads easier on this. both cars are complete and running atm. actually getting the lump in is no probs. wiring and servo clearance are my only issues. i like a challenge
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
Karan
ian correct me if i'm wrong but doesnt the e28 m5 mounts raise the engine a bit as they are quite big? or did u have to do that anyway with ure engine?
and yes ian is the dadd when it comes to wiring!!, hes sorted my wiring out for my m5 project!
cheers
Karan
cheers
Karan
ian332isport
Hi Karan,
I think the E28 M5 mounts are a bit taller than regular E30 ones, but they are what most M50 conversions use (certianly in the US). They are actually used on the 6 series as well, so you sometimes see 6 series mounts referenced.
If my mounts were much shorter, I think the sump would be a bit up close and personal with the steering rack
Ian.
Ian.
randomdave325
- Random E30 Nutta
i'll pm you ian when i start having wiring issues. if thats cool with you
nice one for the mount advice. that will save a load of hassle
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
ian332isport
Yeah, just send me a PM, and we'll sort it out.
Ian.
Ian.
randomdave325
- Random E30 Nutta
The current fleet!
1990 318iS
1984 528ise
1987 325i sport
1990 325i cabrio
1987 m3 s50b30
ian332isport
Just to follow up on this one.
There was no way in hell that the torx bolts were going to come undone. I eventually had to remove the bumper shocks as described above. This was all well and good, but I still had the bumper shock well and truley stuck to the back of the bumper.
I eventually decided to completely strip the bumper down to get the shocks and their mounting brackets off the bumper. Once this was done, I took them to my friendly garage and had a go with a windy gun. Not a chance..... these bad boys were not going anywhere. We eventually got them out with the aid of an oxy torch, windy gun and hammer
The problem is not that the threads get rusted, but the shaft of the bolt gets rusted solid into the tube on the end of the bumper shock.
Everything is now nice and free again. I just need to get the bumper back from the bodyshop and fit the carrier back into the M-Tech bumper/lower valance assy.
Ian.
Ian.
