can you help?
my drivers side window goes down perfectly every time but.....
on the majority of occassions when i do it up it goes up a bit, then sticks, then goes up a bit more, then sticks etc..etc.... (taking me about 2 minutes to do my bloody window up!)
then on the other hand some times it works perfectly!?
its probably quite blantently an electrical problem ( possibly a loose wire) but in that case why does it go down perfectly every time?
cheers
sticking electric window!
duffs17
Gwynleym10
take the door car off
clean motor and rails with carb cleaner or wd40
grease as moving parts
job done
job done
Chris-W
Gravity!duffs17 wrote:but in that case why does it go down perfectly every time?
Do what Gwyn says.
duffs17
