First Post and a MOT question
andyborris
Post Thu Jul 20, 2006 6:14 pm
Hi,
First post, so be gentle.
Had lots of older BMWs (2002s & E28s) got my first E30 (a 318i) about 2 months ago as a cheap runaround and was converted within a mile!
Now just bought a M50 325 Touring and have a question, does a 1990 car need a cat?
Andy
Zayyan
Post Thu Jul 20, 2006 6:17 pm
Nah.
Only losers with late K/L plate cars and newer need one.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Jul 20, 2006 6:37 pm
no cat for u how about a exhaust upgrade winkeye
welcome to the zone
jmc330i
As above, you dont need a Cat.
Even if the M50 had a Cat before, IIRC its down to the age of the car, not the engine - it still needs to pass the emission test though.
James
'91 325i Sport
'93 318i touring 16v
andyborris
Post Thu Jul 20, 2006 6:38 pm
Excellent! This is the first car I've owned that's been made after 1972!
Thanks for the info.
Andy
Post Thu Jul 20, 2006 6:39 pm
its down to which ever is oldest actually... engine or car
jmc330i
Post Thu Jul 20, 2006 6:47 pm
Jhonno wrote:its down to which ever is oldest actually... engine or car
Ah, I knew it was something like that. I guess with my conversion I just thought car rather than engine.
James
'91 325i Sport
andyborris
Post Thu Jul 20, 2006 9:17 pm
[quote="cliffybabe"]no cat for u how about a exhaust upgrade winkeye
Any suggestions? It's also on standard springs and dampers.......don't want to lose too much ride comfort, but would to like fling it around Cadwell once in a while too!
What's best value for the suspension and I know that's not necessarily the cheapest!
Andy
Post Thu Jul 20, 2006 11:49 pm
Touring suspension etc. is not bad in the first place - far better than the equivalent saloons, especially on the non 325 models.
Could use a bit of lowering, but don't use saloon rear springs. Cabrio ones are OK though.
andyborris
Post Fri Jul 21, 2006 7:50 am
Brianmoooore wrote:Touring suspension etc. is not bad in the first place - far better than the equivalent saloons, especially on the non 325 models.
What's the difference?
Or is just the extra power and weight pushes the suspnsion to it's limit?
I'm going to replace all the wear points in the suspension (bushes, balljoints) and at the same time fit new dampers (shocks). Any recommendations as to which ones and suppliers? Do M3 parts fit and are they a good choice? Or should I go with a polybush?
I'll probably fit new springs too, I'm thinking standard rates, but a little lower (25mm-ish)
Andy
Post Fri Jul 21, 2006 8:45 am
Tourings have Mtech uprated suspension as standard, rear ARB, vented front discs and solid rear discs. 325 touring also has alloy front control arms from the M3.
Don't like polybush personally. Go with OE, but use M3 front control arm bushes, either offset or not, and E46 cab rear damper top mounts.
H R cup kit from the zone shop gets good reviews.
andyborris
Post Fri Jul 21, 2006 9:08 am
M3 offset bushes give more neg camber?
Andy
