ARB Bracket question
SD
Post Tue Jul 18, 2006 4:00 pm
The right front ARB bracket on the Touring has broken. Metal fatigue has taken it's toll - and it is only held on by the back bolt.
Are the brackets held on by just bolts into the subframe, or is it a nut and bolt affair? PITA to get on and off?
Post Tue Jul 18, 2006 4:23 pm
one end has a lip the other is nut and bolt
DaveD
E30Zone Wiki Specialist
Post Tue Jul 18, 2006 4:43 pm
As Jhonno say one end is a lip the slots in and the other has to be bolted ,,,having watched my mechanics do it, it is a right sod to get on,,,you def have to have it on stands with the arb link arms undone and have an assistant to push with a tommy bar whilst the other puts the nut on
Templ8e30
Post Tue Jul 18, 2006 4:47 pm
It's a nut and bolt affair, piece of cake to remove but can be a b@stard to get back on.
Best way to refit is; use screwdriver to line the holes up whilst clamping the bracket to the subframe with a pair of mole grips.
Best of luck
Iain T
2007 Mazda 6 2.0 estate
doughboy
Post Tue Jul 18, 2006 10:13 pm
Did mine at the weekend, and yeah it can be a pain..
Cleaning up the arb and the clamp properly helps alot. I used a screwdriver for alignment and then another jack to force it into the correct position.
