Knocking
Dan318-is
Post Sun Jul 16, 2006 4:39 pm
i installed my new alloy arms today with eccentric bushes, went pretty well considering i was melting
however, once the arms had been fitted and i went for a drive, there was a knocking from the left side. its only when the car is being driven, not when the car is stationary. It also only happens once the wheel as done abou a half rotation, then it does not occur for the rest of the turn.
the ball joints were cheked before fitting by a competant garage so i know they are fine, they also fitted the bushes. All the bolts are tight, iv triple checked them all and also nothign is knockign or clearing, iv double checked that when the wheel is turned also.
help!
georob
Post Sun Jul 16, 2006 5:35 pm
I get the same when going round left hand bends, still cant suss it out. :mad:
If you do, let me know what it was
Thanx
Jon_Bmw
Dangerous when thinking
Post Sun Jul 16, 2006 5:44 pm
Hmm it does sound like ball joints to me. Do they do it when turning a corner more or the same amount as if you were on a straight. Is it vertical motion that sets them off, i.e over little bumps and lumps in the road.
Dan i remember you posting a topic on ball joint rubbers or the like, did you replace the rubbers before the garage inspected them or something? Did the ball joints move freely when you had them off the car.
Last thing, did you change anything else whilst doing the arms, or did you remove/move/knock anything.
Simple questions...but hopefully they'll lead to simple answers :thumb:
Dan318-is
Post Sun Jul 16, 2006 5:48 pm
dude, the ball joints themselves were checked with the rubbers removed by the garage and all deemed to be spot on. im now using the rubbers from my old arms, of which only one was slightly split which was a result
ball joints moved freely yes! i changed the links obviously i think this might be the cause but it is definatly bolted down correctly and in the right position so im a bit confused! especially as its only on the left side
Dan318-is
Post Sun Jul 16, 2006 9:21 pm
anyone?
6inline
Post Mon Jul 17, 2006 7:33 am
I've experienced that recently...and it turned out to be the disc protectors(pushed when changing the steering) touching at a particular moment the steering ball-joints...Hope this is the reason, as I've spend two weeks snooping around the car to find it out
Bob_S
Post Mon Jul 17, 2006 7:47 am
check your top mounts, my mate changed his lower wishbones and his top mounts started to knock like a bugger then again he did ruck it and cause a bit of damage check them either way
Bollocks to this 24v scrap!
Dan318-is
Post Mon Jul 17, 2006 10:14 am
6inline wrote:I've experienced that recently...and it turned out to be the disc protectors(pushed when changing the steering) touching at a particular moment the steering ball-joints...Hope this is the reason, as I've spend two weeks snooping around the car to find it out
Good call! they did look a bit shagged!
Bob_S wrote:check your top mounts, my mate changed his lower wishbones and his top mounts started to knock like a bugger then again he did ruck it and cause a bit of damage check them either way
Whats the procedure for checking top mounts bob?
Bob_S
Post Mon Jul 17, 2006 10:54 am
er, dunno ask someone else lol just drive about and see if you can tell where the knocking is coming from
Dan318-is
Post Mon Jul 17, 2006 11:40 am
i checkd the backplate im im 90% its not that. the thing is it only happens when your driving so its a real pita. its definatly coming from the front left and a few passengers have said it feels like its coming from underneath the car. i did a free play test thing on the wheel from side to side an there was a small bit of play.
its ball joint isnt it :cry:
Dan318-is
Post Mon Jul 17, 2006 2:45 pm
tightened up the ARB link earlier, even though it wasnt that loose, and it threaded and is just spinning. its the 13mm bolt/nut that goes through the bottom of the link/wishbone. the knocking stopped for a while. then on the return journey home, it began knocking again on the left side only, but it now knocks on left turns, right turns, and bumps?
Dan318-is
Post Mon Jul 17, 2006 5:15 pm
BTTT someone must know!
Demlotcrew
Post Mon Jul 17, 2006 5:19 pm
Buy a new bolt that you rounded off and see if that fixes it.
Andrew
Post Mon Jul 17, 2006 5:20 pm
ball joints should be nice and tight.. when they get loose they are worn
can you feel it through the steering wheel?
Dan318-is
Post Mon Jul 17, 2006 5:28 pm
cant feel it through the wheel. can only here it, passengers can allegedly feel it when it knocks hence why i hope its something clashing.
what are the symptoms of warn ball joints?
the garage checked them and said they were fine, no vertical movement, and they seemed stiff but moved without any hastle or excess force when they were off the car
il try that bolt but i cant see it being that to be honest!
georob
Post Mon Jul 17, 2006 5:55 pm
I totally have the same prob as you
So far there has been new control arms, tie rods, tie rod ends, tie rod cv's, balljoints, offset control arm bushes. arb links, arb brackets/bolts and struts
Still the bloody knocking :x :mad:
Theres bugger all left for me to replace, the rack is aok as had that checked. And new wheels fitted/ balanced, tracking 100%.
Now i'm poss thinking the top mounts gone perhaps? What are the symptons for these failing???
Dan318-is
Post Mon Jul 17, 2006 6:03 pm
i thought top mounts, but why would the top mount start knocking as soon as i fitted a lighter wishbone? does yours knock on straights as well as corners?
Post Mon Jul 17, 2006 6:04 pm
could be your shagged control arm bushes
probably a ball joint though. How competant are they? how can u check a worn ball joint off a car?
Jack it up on that side and move the wheel, jiggle it if there is some play there it's most likely the ball joints bert
Dan318-is
Post Mon Jul 17, 2006 6:09 pm
allready done the good old wiggle the wheel test. there is a tiny bit of play but nothing out of the ordinary to me. i compared both sides and the quite side has hardly any more noticable play than the other.
the bushes may not be bmw but they owuld not cause knocking, bert :evil:
georob
nah, just on corners it knocks
not my balljoints as brand new feckers fitted
Dan318-is
Post Mon Jul 17, 2006 6:10 pm
is it only noe side of yours which is knocking rob? mines on straights too so im beginning to think it is the ball joints
what will the effecst be if they aint replaced etc?
might get the garage to look tomorrow :?
