There seems to be loads of play in the shaft of my gearstick - is this normal?
Changes gear sweet but even when in gear i can move the stick about an inch or so side to side.
Normal 325ism or worn bits?
Matt
That's right, if you get everything on the list your gearchange will be TIGHT and you'll have the added bonus of the short shift.TouringMatt wrote:Thanks for the replys guys![]()
So what your saying Adam, is if i get everything on this list
then i will ( after removing the prop) have a tighter gear change and a short shift too?
IYO does it really need the gearshift rod joint changing?
I personally dont find it too bad - but i like things to be right![]()
Matt
