IS owners with ITG
appletree
Post Thu Jul 13, 2006 5:29 pm
has anyone put one of thesew ITG filters on the IS?
what was the difference like and was there and hesitation at 2.5K rpm? :D
cheers,matt
appletree
Post Sat Jul 15, 2006 4:29 pm
bump :D
Demlotcrew
Post Sat Jul 15, 2006 4:40 pm
Do you know if the car is running 100% the hesitation could not be related to the filter. Just make sure the engine tests out 100 before thinking the airfilter is causing the problems.
Andrew
appletree
Post Sat Jul 15, 2006 8:51 pm
with the standard air filter there is no hesitation, only with a k&N style.
look at the dyno results in "my new cold induction air filter+ dyno run" and youll see the huge dip in torque!! M5pilot seams to thing an ITG filter would fix it as they have an intergrated trumpet like the standrad air box :D
