6x9's
jon_pure_british
Post Sat Jul 15, 2006 11:17 am
how can i fit them? i haven't really looked but the boot seems solid, is there any type of pod i screw in that they can sit in?
ta
jon
Clacton-On-Sea
Essex
kam325itouring
Post Sat Jul 15, 2006 12:11 pm
hi
6x9s in an e30 is hard work!!!! :(
all the e30s ive done ive put 16cm 2 ways or 3 ways in. you can get good bass response out of them, if you go for jbl or infinity 16cm speakers the chasis is designed in a way that you can squeeze them into a 13cm hole with minor cuttin of the top fibre board, when i did my 87 e30 they slotted straight in.
but if you still want to go down the 6x9 route, there is a lot of cutting on the top board, dependin on the size of the magnet you may have to cut the metal underneath!! which i try to avoid.
eko
Old timer
Post Sat Jul 15, 2006 12:38 pm
Jon you can buy speaker risers for 6x9`s,saves cutting the shelf!
hoshy
E30 Zone Wiki Guru
E30 Zone Wiki Guru
Post Sat Jul 15, 2006 1:10 pm
I cut the shelf (not the metal) and then used some plywood to make a shelf that stretches all the way across the back shelf to raise the 6x9s up enough to fit.
pictures are on my work pc but I'll post soon.
jon_pure_british
Post Sat Jul 15, 2006 1:16 pm
hmm i like the idea of the plywood, but id rather not cut the boot at all.
but i like the sound of speaker risers even more.. where can i get these from mate?
Clacton-On-Sea
Essex
eko
Old timer
Post Sat Jul 15, 2006 6:34 pm
Well a mate of mine got some not long ago,about £15 i think,from Autoquip,if you have one local to you,if not im sure Halfords do them?
Made out of Black plastic,about an inch in depth i think!
Dan318-is
Post Sat Jul 15, 2006 6:40 pm
eko wrote:Jon you can buy speaker risers for 6x9`s,saves cutting the shelf!
Should have told that to the owner of my Is :(
d6dph
Post Sat Jul 15, 2006 8:50 pm
Jon, go to Gk's on north station rd and we sell maystar mdf rings to space 6x9's, either that or cut your own which would be cheaper.
Gwynleym10
Post Sun Jul 16, 2006 12:17 am
Same here!
London 2 Cape Town
www.Overlandinthesun.com
jon_pure_british
Post Sun Jul 16, 2006 12:20 am
do they just screw on?
Clacton-On-Sea
Essex
eko
Old timer
Post Sun Jul 16, 2006 12:34 am
Jon,ive got a pair of 3/4" MDF 6x9 spacers here if you want them?
Painted Black so would look better cloth covered!
jon_pure_british
Post Sun Jul 16, 2006 1:11 am
how much pal
Clacton-On-Sea
Essex
eko
Old timer
Post Sun Jul 16, 2006 1:17 am
jon_pure_british wrote:how much pal
Couple of quid to cover postage :)
Cotty
Hartge Crew
Post Sun Jul 16, 2006 6:18 pm
I suppose I kind of bodged my install but I thought they looked good. I put 6X9's in my 316. I got some MDF rectangles cut out the holes using a jigsaw and spayed them mat black and mounted the speakers on them bolted (long bolts) to the metal shelf.
Was very secure 8O
