So I've swapped my engine, and it still has the same damn problem. They guys at the mech shop said that it could be the wiring loom, running from under the dash into the motor bay. Is there any way that I could check if this is the problem, without paying out my rear end again??
Problems are that it seems as if the motor is stuttering when under load - no matter what gear, or what rpm. Changed the dizzy, the rotor, the motor, basically everything except the wiring.
Any idea, PLEASE guys!!
Well, now what?
jog5000
E30Mark
long shot, have you checked the battery / alternator? and the connecting cables?
PM for details
PM for details
