Heater Matrix question.....
Paulsimon8
Post Thu Jul 13, 2006 2:16 pm
The E30 heater matrix.
Can anyone tell me if it allows coolant to flow thru it continually, regardless of what position the heater dial is in on the dashboard.
Or is it the type that has a valve to stop the flow of coolant when the dial is turned to cold.
Its very important I know this, or I could overheat and damage the YB engine due to the way the coolant system works on a YB winkeye
Paulsimon8
Post Thu Jul 13, 2006 7:37 pm
bttt please :mad:
ian332isport
Post Thu Jul 13, 2006 9:01 pm
There's a solenoid valve on the side of the heater unit that shut's off the water flow when the temp dial is turned to cold. Infact, the valve is closed for the first 20 degrees of dial movement.
Ian.
Post Thu Jul 13, 2006 10:28 pm
Easily dealt with, though, if you need a constant flow.
Paulsimon8
Post Fri Jul 14, 2006 7:03 pm
Hi Brian, Cheers for the reply winkeye
How do I deal with the solenoid valve to give it a nice constant flow please?
obviously I have to give the solenoid a constant supply to keep the valve open, but where abouts is the solenoid? :mad:
Cheers winkeye winkeye winkeye
Post Fri Jul 14, 2006 11:10 pm
Paulsimon8 wrote:Hi Brian, Cheers for the reply winkeye
Easier than that! The valve is powered shut.
Part of the valve is actually the black stub pipe that goes through into the engine bay. Body of the valve is behind the panel to the right of the glovebox, and has a little in line fuse close to it.
Pull the fuse and the job's done.
Paulsimon8
Post Sat Jul 15, 2006 3:51 pm
Cheers Brian - you are a star 8) 8) 8)
