Anyone come across the situation where the bottom of the cabrio hood obstructs the door window when trying to shut the door?
The cab I bought recently had a new (non-BMW) hood put on last year according to the previous owner. It is in good condition, so no complaints there. But when I come to shut the driver door, I have to either (a) lift up the hood's bottom edge, or (b) push the door by the left window corner - otherwise the bottom edge of the hood gets wedged between window and car frame (see photo below).
Any ideas on whether this is an easy fix? My fear is that this will require an entire hood replacement. The previous owner said that it there was a tensioner of some description along the inside of the hood mechanism that just needed replacing, but I don't know if this is true.
By the way, this only happens on the driver's side door. The passenger side door seems to be free of this issue.
Here's a photo of the problem. Not having much luck with this hood of late...
Ben
