To much
ed325i
Post Sat Jul 08, 2006 12:24 pm
I have got to much camber on the front of my e30. Can anyone recomend me a good adjustable top mount. It would be nice to use all of the tyre and not just the inner 1 1/2" :roll: .
ED
ed325i
Post Sat Jul 08, 2006 8:15 pm
All the people on here with lowerd cars and no one has adjustable top mounts 8O
ED
fuzzy
He who sleeps with "Gingers"
Post Sat Jul 08, 2006 8:19 pm
how much have you lowered it by?,mine is -60 at the front with no problems,i only have problems at the rear with -40 :?
maxfield
PM sal id be suprised if he cant get ya any
ed325i
Post Sat Jul 08, 2006 8:40 pm
Its lowerd all round by 35mm but it has a m30 engine in the front now. when I had the suspension set up they said that it would need adjustable top mounts. Do you think it does from the pic ?
I have got to sort the rear out as well.
ED
handpaper
Post Sat Jul 08, 2006 9:31 pm
From the pic you've posted and some iffy measurements with KDE Screen Ruler, camber looks to be about -4.5deg, which is a bit excessive. Recommendations seem to vary from 1-3 degrees, depending on use.
I've just checked mine (lowered 40mm on 15" BBS, standard M20B20) and it seems to have about 6 degrees total. I can't give figures for each wheel because of the camber of the road it's parked on. You have checked that the car is level, right?
ed325i
Post Sat Jul 08, 2006 9:49 pm
Yes the drive is level. I did get a print out when I had it set up but cant find it now so I am now off to look for it.
ED
ed325i
Post Sat Jul 08, 2006 10:18 pm
I cant find it :cry: ireland engineering do these so I might get them unless I can make some winkeye but I can't work out how they bolt on.
ED
Dan318-is
Post Sat Jul 08, 2006 11:36 pm
Ed,
try http://www.rogueengineering.com/Merchant2/merchant.mvc?
or
http://www.bmpdesign.com
the later has a whole range of sexual suspension components i can only dream off
Ant
Retired Team Member
Retired Team Member
Post Sun Jul 09, 2006 12:33 am
:lol:
for a cheap fix, open out the strut mounting holes and use larger washers,not as bad a bodge as you might think.
No need to spend a fortune , unless you plan to track the car ?
Dan318-is
Post Sun Jul 09, 2006 12:42 am
very good ant! how do you know how much to open it buy etc though?
Demlotcrew
Post Sun Jul 09, 2006 9:52 am
Ed im going to buy BMW's own ones which can only adjust two ways but they are stock and wont affect the ride. £104.00 inc vat for the pair.
Andrew
ed325i
Post Sun Jul 09, 2006 11:24 am
Demlotcrew wrote:Ed im going to buy BMW's own ones which can only adjust two ways but they are stock and wont affect the ride. £104.00 inc vat for the pair.
Andrew
That sounds good I head they only increased the neg but if they give you pos as well that great. Are they the ones that where used one some m3's ?
ED
