quick actuator question?
fuzzy
quick question regarding actuator rods, does shortening the rod increase or decrease boost? ive got 3 psi to play with as the limit for my chip and injectors is 18psi and as im only at 15psi it would be a shame not to use it
e30_Turbo
- Boost Junkie
fuzzy
thanks mate,i think there about 20-25mm of thread left on the -31 actuator rod so i should get a bit more boost from that .i havent fitted my new turbo that i bought last week yet so it doest matter if i manage to break it
Turbo-Brown
- Boost Junkie
Speaking of which, gotta turn up 3 bungs and yours is done Markfozzymonster wrote:Shorter = more boost!
Most actuators will only give a few psi adjustment, best bet is a controller although I have played with bleed valves and they certainly work but they're very crude devices.
HTH, Mark.
fuzzy
guage is now reading 17psi so i guess i should alter my sig
jonsmiff
did you pre-load the actuator m8?
