I'm just about to this very conversion. Just as soon as soon as I get my new MOT this week. So, looking to do this weekend.
I'm about to order the end of the crank pilot bearing and accompanying parts from BMW. Do i need a new spacer ring as it is a different part number compared with the auto?
Also, thought I'd pop on a shorter shift while I'm there. I read the z3 1.9 is fine (with an "adjustment" to the rod) but some say the 2.8 is better if slightly notchy. (I have a Z3 2.8 car and the gear change is notchy in that if you don't disengage the clutch fully.)
I read here somewhere that you have to remove the propshaft rubber guibo to use the 2.8 gear lever?
