Chipped or not?
less2303
Post Fri Jul 07, 2006 9:00 pm
Just taken the ECU out of my Tec 1 and was wondering if it has been chipped or not, anyone any idea?
Ant
Retired Team Member
Retired Team Member
Post Fri Jul 07, 2006 9:06 pm
Stock as a rock mate and a 24 pin ECU too.
there are 4 holes in the PCB t convert to the later 28 pin Eprom required.
If youy can solder, there as lot to be had from chipping the higher compression Engine in the Tech 1
dazleeds
old skool raver
old skool raver
Post Fri Jul 07, 2006 9:09 pm
Ant wrote:Stock as a rock mate and a 24 pin ECU too.
eye eye tell me more mate
does this mean you can chip up my tech 1 easily then??
www.oldskoolfantasy.co.uk
Ziggy
Post Fri Jul 07, 2006 9:13 pm
Oooooh yes he can! winkeye :twisted:
less2303
Post Fri Jul 07, 2006 9:14 pm
You'll have a job with mine, its in 100's of parts across the back yard being broken!! :D
dazleeds
old skool raver
old skool raver
less2303 wrote:You'll have a job with mine, its in 100's of parts across the back yard being broken!! :D
maybe so but the engine will soon be in my hands :twisted: winkeye
so ill be needing 2 chips :cool:
now wheres ant gone too 8O
green-blood
Post Tue Jul 11, 2006 2:55 pm
hey
I've been diging around about BBTB and zone chips for mmy 86 325 tech1 sport, I'm assumming it'll have the same 24 pin layout above, now I'm well confused on how to get a 24 pin board to accept a 28 pin chip, I'me not a soldering/electronics expert at all.
any guide/info gratefully received
whats worse I'm in Ireland so no "nipping" down to Ant, who to me lloks like God right now!!
dazleeds
old skool raver
old skool raver
Post Tue Jul 11, 2006 3:16 pm
green-blood wrote:hey
pm ant fella
im sure he would be prepared to sort the ecu and chip it for you
maybe on an exchange basis for a few quid extra??
gotta be worth asking hasnt it??
Daz
green-blood
Post Tue Jul 11, 2006 3:17 pm
good plan
cheers
Ziggy
Post Tue Jul 11, 2006 11:08 pm
There's no guarantee it'll be a 24-pin board in your ECU - they way I understand it, most of them were replaced so you'll have no problems. Mine was 24-pin though, but it really is easy to fit the new ones... Ant (legend that he is) sent me them, & the holes are there in the board, ready for em to drop right in...
If you've never soldered anything, I'm sure you must know someone who has? :thumb:
green-blood
Post Mon Sep 18, 2006 3:35 pm
modded ECU in the post from Ant
hurry up mr postman
cheers Mr Ant
Ant
Retired Team Member
Retired Team Member
Post Mon Sep 18, 2006 4:43 pm
NP Dude, she's gone via Airmail so should arrive fairly rapidly
Ziggy
Post Mon Sep 18, 2006 11:27 pm
You won't be disappointed! :D
Ant, will say hello on Sat - maybe you'll remember who I am this time; spoke to ya (briefly) at Gaydon & apparently you didn't recognise me. Sniff. :cry:
Ant
Retired Team Member
Retired Team Member
Post Tue Sep 19, 2006 8:53 am
Sorry dude, its the eyesight that lets me down, not the memory 8)
orangecurry
Post Tue Sep 19, 2006 9:19 am
when EXACTLY did the engines change... is there a date or an engine number after which it was the lower compression?
GDBN
Post Tue Sep 19, 2006 9:38 am
Ant .... has my ecu arrived in the post yet ??
G
Ant
Retired Team Member
Retired Team Member
Post Tue Sep 19, 2006 10:24 am
No mate, Jon B was supplying yes ?
I'll chase him up on saturday @ the Pod.
orangecurry
Post Tue Sep 19, 2006 11:22 am
orangecurry wrote:when EXACTLY did the engines change... is there a date or an engine number after which it was the lower compression?
anyone know? I've done a 'search' already
oh and don't say 'if your car is a facelift it'll have the lower compression engine', cos I have a cab and BMW didn't change the body/panels/bumpers on those for a few years AFTER the 'facelift' engines came out....
GDBN
Post Tue Sep 19, 2006 12:02 pm
Ant,
Yep it's JonB ... he should have got the cheque Saturday or yesterday latest.
He has your address and was supposed to sending it.
He hasn't replied to mypm's since friday.
G
And following up with orange here , I presume my engine is the older higher comp. Sep 86 should be I think.
Did have a new head last year ... I presume that won't make a difference. (the head I bought was brand new and the only one in the catalogue was for a "cat equipped" car.)
Ant
Retired Team Member
Retired Team Member
Post Tue Sep 19, 2006 5:56 pm
the late/early engines change over with the swop to plastic bumpers, so pretty much september 87 onwards should be an 8.8:1 bottom end, heads are all the same on the 325, all 885 castings, no change in valves although the early cam certainly has altered spec if you put one against the cat ready unit.
The above info only applies if your car is still wearing its original bottom end, there have been a lot swopped about over the years, so there are a few "hybrids" out there
Andyboy may have info relating to an engine code change ??
HTH
Theo
Post Tue Sep 19, 2006 6:00 pm
What about metal bumpered later cabs, are these early or later compression?
GDBN
Post Tue Sep 19, 2006 8:59 pm
Ant,
The bottom end is certainly original ... now you mention it I think it was the cam that was for a "cat" engine. Suppose that will slow things down a bit !!
Can your wonder chip get around having a "cat prepared cam" ??
G
