on board computer question
alane
Post Fri Jul 07, 2006 8:07 pm
my on board computer temperature always reads -22 degrees no matter what the temperature is ,other functions on the computer work fine any suggestions ?
Dan318-is
Post Fri Jul 07, 2006 8:08 pm
your temperature sensor in the brake duct is either damaged/missing/disconnected i would think mate
alane
Post Fri Jul 07, 2006 8:17 pm
ok but excuse my ignorance im new to beemers where is the duct ?
Dan318-is
Post Fri Jul 07, 2006 8:20 pm
brake duct. look at the front of your car. should be on the lower valance. the right hand side one houses the sensor. it pops in through the top of the duct
alane
Post Fri Jul 07, 2006 8:23 pm
thanks fella will have a look tomorrow
alane
Post Sat Jul 08, 2006 5:37 pm
update- had a look today cant find the duct or sensor -looked all along the inside of the front bumper and inside around the headlight area am i looking in the right place ?
smithy318i
Post Sat Jul 08, 2006 5:40 pm
it should be in the plastic duct on the passenger side of the car. the plastic duct is located right next to the foglight (or the blanking plate, if you dont have fogs)
maxfield
Post Sat Jul 08, 2006 6:01 pm
My dad needs a new one his always reads -30
alane
Post Sun Jul 09, 2006 3:48 pm
had another look today didnt find any duct maybe its missing but i have found a loose plug not connected to anything i figure this may be it ,it was behind the left fog light .
smithy318i
Post Sun Jul 09, 2006 3:56 pm
do you want a set of ducts?
i have a set standard ones for sale
robmpulse
Post Sun Jul 09, 2006 6:16 pm
this sensor is pretty cheap on ebay........
AndrewL
Post Mon Jul 10, 2006 11:03 am
The sensor is £5 from one of the internet e30 breakers. ebay can be dearer.
If you have no sensor maybe someone has retrofitted an OBC to your car and not bothered with the loom and sensor. It often happens. I suggest you find the sensor and check whether you have the loom before buying a new sensor.
alane
Post Mon Jul 10, 2006 1:01 pm
no the obc was definately fitted at the factory its listed on the original invoice which i have in the history file .
