325i suspension replacement
cozmic
Post Fri Jul 07, 2006 1:17 pm
can any one help? my 325i has been lowered by a previous owner & i dont know what springs etc where used . the ride height is fine but it could do with being replaced (on a budget) any ideas on (a) original ride height? (b) what to replace it with i thought abought g-max but dont know if its any good? i know you only get what you pay for but cash is a bit tight at the moment the car is a 325i coupe 1989
CabbyThompo
Post Fri Jul 07, 2006 1:38 pm
Gmax springs are OK!!
For the rear, go to GSF or Euro car parts and get youself a set of gas struts there only abour £20odd quid each and they sit lowered springs nicly!!
There is an Ebay shop that sells good springs for cheap!! winkeye
(Don't touch the shocks!!! There CRAP!!)
Dont put cheap shocks on the front!! it will cause you loadsa problems!!
Go for a good set!!
ile post up the ebay shop in a min....
CabbyThompo
Post Fri Jul 07, 2006 1:41 pm
Performace FX (Ebay Shop)
http://stores.ebay.co.uk/Performance-Fx
(Shocks are nasty!! 8) )
massive
Post Fri Jul 07, 2006 2:27 pm
cozmic wrote:can any one help? my 325i has been lowered by a previous owner & i dont know what springs etc where used . the ride height is fine but it could do with being replaced (on a budget) any ideas on (a) original ride height? (b) what to replace it with i thought abought g-max but dont know if its any good? i know you only get what you pay for but cash is a bit tight at the moment the car is a 325i coupe 1989
If the ride height is ok, why are you wanting to change? Are the dampers fcuked or something?
wullie325i
CAUTION - unreliable trader!
Post Fri Jul 07, 2006 2:49 pm
hi
get a spax psx kit i got one that lowers my car by 40mm and the shocks are 28 stage adjustable.its a really good setup.
wullie
fuzzy
He who sleeps with "Gingers"
Post Fri Jul 07, 2006 3:07 pm
like you need 28 different settings :mad: the spax kit is £350 though and he did say money is tight.i had the spax kit on my touring and i found it to harsh even on the soft setting so i changed to bilsteins and its good now winkeye
