The metal elbow that (from memory) goes from the throttle body, to some rubber tubing, that is in turn connected to the Idle Control Valve:
Where the metal elbow inserts into the throttle body, should there be a gasket or seal of any kind at that join?
Seems a little loose otherwise (as mine is).
ICV into throttle body
AlpineCab
Jackle
I think the answer is no.
I just changed the throttle body on my car, and there is a similar elbow on the other side that connects a pipe to the brake vacuum servo. The replacement throttle body I got didn't have that elbow, just a couple of holes. I just eased it out of the old TB with a screwdriver and tapped it into one of the holes on the new TB (temporarily filling the other hole with a rubber stopper and a screw, don't ask!).
There didn't appear to be any seal or gasket on this elbow, it's just a snug fit. I would assume that the other elbow is identical.
Ant
- Retired Team Member
they are peened to fit snug @ the factory, loose units can cause running probs .
remove and gently peen the ends over and refit, or use some threadlock or a drop of aralidite/threadlock to re-secure them.
Make sure the "glue" is dry before running the car though dudes
its a common problem
Email FTW
AlpineCab
Mine is definitely loose.
What is "peen"?
Would some liquid gasket sealent, such as Hylomar Blue, be OK to make the seal tighter?
What is "peen"?
