appletree
Post
Thu Jun 29, 2006 8:16 pm
Heres my new air filter and a stainless heat shield i made
and a nice square to round converter machined from billet and tappered to keep the air flowing what do you think?
i've also just put my new camcover on, manifold to come later.
Opinions???
Post
Thu Jun 29, 2006 8:22 pm
very nice mate, looks a quality job
if only the zone shop could provide something like that for the ITG filter
d6dph
Post
Thu Jun 29, 2006 8:24 pm
Very nice fella.
Does it seal to the underside of the bonnet too?
gooner1
- Out humping Reindeer
Post
Thu Jun 29, 2006 9:19 pm
Simon13 wrote:very nice mate, looks a quality job
Exactly my sentiments,dont fancy going into mass production do you apple tree?.
appletree
Post
Thu Jun 29, 2006 9:34 pm
if you're intrested ive got a ally mock up i made? not very pritty but if it was on a track slag it would be ok.
Does it seal on the boonet? dont know, i cant see? but i was gonna put sum bit bigger rubber on the top to try make the rubber touch the bonnent, its got to be pritty close. though.
i could send you the dimentions or a template to make your own if you were intrested???
d6dph
Post
Thu Jun 29, 2006 9:38 pm
Use a long sausage shaped bit of bluetak or the like and place on the top edge of the shield. shut the bonnet and if it gets squashed its sealing!
Be interesting to know as it looks really well made and i think you could make a few £Â£ out of the design.
Very good work tho fella.
ed325i
Post
Thu Jun 29, 2006 9:41 pm
Wouldnt take alot to put a lid on it. Looks good I need to make one for my 5.
ED
d6dph
Post
Thu Jun 29, 2006 10:03 pm
That would be easier! lol
appletree
Post
Thu Jun 29, 2006 10:04 pm
ed325i- when you say 5 do you mean 325? or 5 as in R5 GTTurbo? its just my mates realy in to renualt 5s
I migth make a small batch? what they worth
?? the only problem is with all the different length/dia filters out ther they might not fit every ones, i also made the hole to suit the bend of the rubber going in to the throttle body, this mightr be different on a 325
as for the bonnet seal, al have a go with the blue tak idea. i would have thought the cold air rushing in would push any hot engine bay air trying to com in over the to out??? would you agree?
Dan318-is
Post
Thu Jun 29, 2006 10:06 pm
I would be interested to see a R/R session with before and after results on. Previous test have shown (allegedly) that the Is engine does not react well to cone filters and actually losses torque. i think it even lost it low down, which is where it lacks the most although mb im wrong? I think though with a heatshield like that mayeb there are benefits?
chuck it on some rollers mate its worth it to see if its running right anway
top work so far though
Edit: that metal plate thats sandwiched between the AFM and hosing looks extremly like the heater plate on Is'!!
d6dph
Post
Thu Jun 29, 2006 10:07 pm
oh yeah i agree that the cold air will push the hot air out. nice to try and keep it as sealed as poss.
as of the filter entry, you could use a rubber membrane to create a flexible seal around the fliter neck. rivet it in place? Sorry getting a little carried away! hehe
appletree
Post
Thu Jun 29, 2006 10:10 pm
you could put a lid on it, but its nice to show it off at shows n stuff. maybe a perspeclid?
Would any one be intrested in one if i made the basic plate, edged it but left the drilling of the hole to them?
d6dph
Post
Thu Jun 29, 2006 10:13 pm
if i didnt have my bmc cda i would go for one. Dont forget that some cars have abs so they shield would need modifying around that.
appletree
Post
Thu Jun 29, 2006 10:17 pm
318-is- i know what you mean,
av read in a few places that the standard air box is pritty perfect. IMO it doenst seamed to have gaind or lost, or it doesnt feel like it any way?
as for the "heater plate"
it definayely not, imachined the square to match the AFM then turnd the 3" outer then turned a slow tapperon the inside so it flows round to square.
Rollers would be a good idea, how much is a session?
Dan318-is
Post
Thu Jun 29, 2006 10:28 pm
good good.
mb 50 quid?
M5pilot
Post
Fri Jun 30, 2006 1:29 am
Nice work!
Heathshields in E30's are not as effective as people think. I'll carry out my tests again of air intake temp vs atmospheric temp. Maybe in this hot weather a heat shield would be beneficial. I did my tests in winter.
The reason you lose torque with most cone filters is because you lose the trumpet which directs airflow. You also lose throttle response.
The ITG filter has three main benefits:
1) Foam is very free flowing
2) Trumpet inbuilt - no loess of torque
3) Metal mesh behind foam which does 2 things
a) Stops foam being sucked in
b) Smooths airflow.
The ITG filter is however very expensive.
Sal
appletree
Post
Fri Jun 30, 2006 7:24 am
Al get a picture of my converter over the week end and post it up as it does sort of have a trumpet.
cliffybabe
- Powered by Nelly
Post
Fri Jun 30, 2006 9:41 am
I've got the ITG filter on mine and its wicked.
I've got to make some sort of plating to keep the heat away, that looks wicked mate
ed325i
Post
Fri Jun 30, 2006 11:32 am
appletree wrote:ed325i- when you say 5 do you mean 325? or 5 as in R5 GTTurbo? its just my mates realy in to renualt 5s
No I mean BMW 525 sport.
ED
appletree
Post
Sat Jul 01, 2006 10:17 am
Hears the converter i machined.
The sound is mint and it does pull better at 4k onwards
BUT like "318is" said it does seam to have lost a little torque lower down it just hestates
at about 2.5K-3K RPM. am pleased though.
as well the IS seams to rev high even, 3k at 60mph so you seam to miss the flat most ot the tme.
would it help if i tryed to put the square plasitic trumpet from inside the old air box in the induction line????
appletree
Post
Sun Jul 02, 2006 4:57 pm
do you think the tapper on the converter would act a little lick the trumpet in the normal air box?
M5pilot
Post
Sun Jul 02, 2006 8:25 pm
The taper in the converter is an excellent idea. However you filter still has flat areas in the back plate which is just causing turbulence.
You still need a trumpet.
Sal
appletree
Post
Sun Jul 02, 2006 9:23 pm
so would it help if i say put the trumpet out the air box in the hole in my converter? or would the length of pipe i have from the filter to the AFM be acting like a realy long trumpet?
M5pilot
Post
Sun Jul 02, 2006 9:55 pm
Why don't you just attach an ITG filter to it and be done with it?
Your adapter is bloody excellent I have to say, again!
All you'll need is some Samco Hose (or HKS) and the filter will fit very nicely.
Do not use the standard factory trumpet, it's square! You wan't a smooth as possible flow of air and so far your going in the best possible direction.
You can purchase an ITG filter on it's own from the me - just email me on
sales@xsperformance.co.uk
We did alot of research into airfilters before making a decision to use ITG.
Sal
appletree
Post
Mon Jul 03, 2006 9:44 pm
hi, thanks for your coments!
what exacly is the ITG Filter? you got any pics or cut away shots to show the inside?
i'm proud of the converter, i made it my self on my dads lathe and miller dint think i did bad for Only 18!
i'd quite like to try and make somthing my self, as thats what i love doing Best!
Cheers, Matt
gooner1
Post
Mon Jul 03, 2006 9:52 pm
HI mate,if you do a search for itg under my username youll see pics of the filter fitted to my car.Cant praise it highly enough,and a nice subtle sound too.Your shield looks the biz mate.
appletree
Post
Tue Jul 04, 2006 7:16 am
Cheers gooner1, so did you think it made much difference? am going halfs on a rolling road with a mate for the afternoon so al soon see what its doing!
gooner1
Post
Tue Jul 04, 2006 9:21 am
To me mate it made a hell of a difference.My cab came with a k&n cone filter fitted, made a nice noise but thats about all.On the first drive after fitting the itg filter it was like driving a different motor, much more responsive throughout all gears and in my opinion a much better sound.
cliffybabe
- Powered by Nelly
Post
Tue Jul 04, 2006 11:37 am
gooner1 wrote:To me mate it made a hell of a difference.My cab came with a k&n cone filter fitted, made a nice noise but thats about all.On the first drive after fitting the itg filter it was like driving a different motor, much more responsive throughout all gears and in my opinion a much better sound.
Mine had a standard box with a K&N element, The ITG is great, u couldnt of worded it better
appletree
Post
Tue Jul 04, 2006 8:14 pm
Has anyone got a dyno result with the ITG filter only? i would like to compare it mine when i put it on the rollers onthe 12th.
cliffybabe
- Powered by Nelly
Post
Tue Jul 04, 2006 8:16 pm
ask sal he might
appletree
Post
Wed Jul 12, 2006 10:30 pm
well i went to the rolling road today with my mate,
The dyno showd that the filter gave a better "peak" torque but not a very good curve and dropped 2BHP
were as the BMW standard filter dropped 3lb/ft but gave a better curve through the rev range and gave 2bhp over the cone filter.
After all the work i put in to making the new set up i realy wanted it to be better than standard
o well bmw got it right in the first place
With cone filter
with standard set up
my mates R5 GTT!
M5pilot
Post
Wed Jul 12, 2006 10:33 pm
Don't dismiss it yet!!
how many runs were done with the stock airbox and cone filter?
A 2 bhp top end loss can be down to the dyno.
The fact that your kit gave more torque is a good thing. I can't see anyway it could lose you top end power. Maybe the use of a different or larger filter could change this.
Sal
appletree
Post
Wed Jul 12, 2006 10:42 pm
maybe but have you seen the dip a 2.5k on the run with the filter? plus the cone filter runs a lower curve compared to the standard filter all the way through apart from at the top.
its good to try them out, a chip might help.
what was intresting is with the standard filter you dont feel any hesitation, with the cone you feel quite abit a 2.5krpm area but i took the filter element out of the air box and fitted my cone filter to the inlet where the cold air should come in ( i only did this for ia quick run up the road when i got home), this had only a very slight flat spot and pulled better than standard ( but a flat spot was still there) this makes me wonder why? as the trumpet was still in there just the amount of air avalable changed?
that make sence Sal?
appletree
Post
Wed Jul 12, 2006 11:00 pm
is a 104 bhp at the wheels agood figure?
i know there was a big thread on this but the man at the RR said he always said 30% drive train loss for a RWD
and 25% for a FWD
so if thats right mines running pritty good?
