Rev counter's Jumping
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Jul 04, 2006 8:02 pm
When im not moving and rev up it glids through but when im driving the car it seems to jump now and then
Any thoughts
Could i just take apart the dials and clean up the needle and move around a few times to free up??
Neil
stuartgallafant
Post Tue Jul 04, 2006 9:20 pm
ive known a couple of E30's to do this!
i think its just that he cluster likes to go a bit spastic once in a while!!!
robmpulse
Post Tue Jul 04, 2006 9:33 pm
does it do this the same time you are hitting larger than normal bumps in the road?
Danny06
Post Tue Jul 04, 2006 9:48 pm
My own sport would do the same but woz told from a few different people that it because i have a high lift cam fitted :?:
Turbo-Brown
Boost Junkie
Post Tue Jul 04, 2006 10:21 pm
Cam shouldn't make a difference I wouldn't have thought, a lumpy cam shouldn't make the engine speed jump about that much!
Mine seems to move up smoothly, but sometimes you can catch it moving down in a series of kinda steps.
Just put it down to the Emerald ECU to start with as I'd not noticed it happen when the car was standard, but I wonder now having read this.
Post Tue Jul 04, 2006 10:31 pm
Danny06 wrote:My own sport would do the same but woz told from a few different people that it because i have a high lift cam fitted :?:
I wouldn't ask these few different people for any more car advice, if I were you!
Post Tue Jul 04, 2006 10:32 pm
Unplug and reconnect the C101 connector on the bulkhead a few times.
The tacho needle is driven by a couple of gears. On one occasion I had one that stuck occasionally due to a small piece of grit in between a couple of teeth. Would expect this to be better when moving though, not worse.
cliffybabe
Powered by Nelly
Powered by Nelly
Post Wed Jul 05, 2006 12:21 am
cheers guys for the posts.
I have a go at that tomorrow thanks Brian
